Salta al contenuto principale
Creative Zen X-Fi LCD Screen Replacement
Cosa ti serve
  1. Creative Zen X-Fi LCD Screen Replacement, Detaching Front Case: passo 1, immagine 1 di 3 Creative Zen X-Fi LCD Screen Replacement, Detaching Front Case: passo 1, immagine 2 di 3 Creative Zen X-Fi LCD Screen Replacement, Detaching Front Case: passo 1, immagine 3 di 3
    • Using a spudger, wedge the tip between the front and back case to pry them apart.
    • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
    Chiedi a FixBot
    Aggiungi Commento
  2. Creative Zen X-Fi LCD Screen Replacement, Rubber Button Cover: passo 2, immagine 1 di 1
    • The black rubber button pad can be removed by simply picking it up.
    Chiedi a FixBot
    Aggiungi Commento
  3. Creative Zen X-Fi LCD Screen Replacement, Button Input Chip Part 1: passo 3, immagine 1 di 1
    • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
    Chiedi a FixBot
    Aggiungi Commento
  4. Creative Zen X-Fi LCD Screen Replacement, Button Input Chip: passo 4, immagine 1 di 1
    • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
    • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
    Chiedi a FixBot
    Aggiungi Commento
  5. Creative Zen X-Fi LCD Screen Replacement, Access Midsection Plate: passo 5, immagine 1 di 1
    • Lift open the LCD screen and button input chip to access the entire midsection plate.
    Chiedi a FixBot
    Aggiungi Commento
  6. Creative Zen X-Fi LCD Screen Replacement, Unscrew below Button Chip: passo 6, immagine 1 di 1
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
    Chiedi a FixBot
    Aggiungi Commento
  7. Creative Zen X-Fi LCD Screen Replacement, Unscrew below LCD Screen: passo 7, immagine 1 di 1
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
    Chiedi a FixBot
    Aggiungi Commento
  8. Creative Zen X-Fi LCD Screen Replacement, Pull the Motherboard Out: passo 8, immagine 1 di 2 Creative Zen X-Fi LCD Screen Replacement, Pull the Motherboard Out: passo 8, immagine 2 di 2
    • Lift the right edge of the motherboard off the back case.
    • Using two fingers to grip the edge of the board, slide the motherboard out of the case to the right.
    Chiedi a FixBot
    Aggiungi Commento
  9. Creative Zen X-Fi LCD Screen Replacement, Disconnect the LCD Screen: passo 9, immagine 1 di 2 Creative Zen X-Fi LCD Screen Replacement, Disconnect the LCD Screen: passo 9, immagine 2 di 2
    • Use two fingers to peel back the edge of the ribbon connector that is glued to the bottom of the LCD screen.
    Chiedi a FixBot
    Aggiungi Commento
  10. Creative Zen X-Fi LCD Screen Replacement, Unlatch the LCD Screen: passo 10, immagine 1 di 1
    • Using a plastic opening tool, unlock the ribbon connector by unlatching the black lever that pins it on the motherboard.
    • Once the black lever arm is open, pull the ribbon connector out to disconnect the LCD screen.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 13
Ultimi 30 giorni: 55
Tutti i Tempi: 2,039
