Salta al contenuto principale
Cover Panel Disassembly
Cosa ti serve
    1. Cover Panel Disassembly, Cover Panel: passo 1, immagine 1 di 1
      • Find the mating groove running along the side of device. Use an ifixit opening tool to pry the two mating surfaces apart with a twisting motion.
      • Once the surfaces have been separated, using your fingers, pull the two surfaces apart evenly around the edge of the device.
      • During reassembly, be sure to press the two pieces together all the way around the perimeter to ensure good connection.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
To reassemble your device, follow these steps in reverse order.
IUPUI, Team 2-5, Baechle Fall 2016 Membro di IUPUI, Team 2-5, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G5
4 Membri
14 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 10
Ultimi 30 giorni: 47
Tutti i Tempi: 575
