Salta al contenuto principale
Core Assembly Removal
Cosa ti serve
    1. Core Assembly Removal, Unfasten the back cover screws: passo 1, immagine 1 di 1
      • Before starting repairs, take your watch off the charger and power it down.
      • Use a Tri-point Y00 driver to unfasten the four screws on the back of the watch.
      • Don’t worry about removing the screws, they will stay in place in the back cover.
      Chiedi a FixBot
      Aggiungi Commento
    2. Core Assembly Removal, Wedge open the back cover: passo 2, immagine 1 di 2 Core Assembly Removal, Wedge open the back cover: passo 2, immagine 2 di 2
      • Insert an opening tool between the back cover and the metal housing.
      • Twist the opening tool to create a wider gap.
      • Don't fully remove the back cover just yet. The sensor flex cable is still connected to the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    3. Core Assembly Removal, Disconnect the sensor flex cable: passo 3, immagine 1 di 3 Core Assembly Removal, Disconnect the sensor flex cable: passo 3, immagine 2 di 3 Core Assembly Removal, Disconnect the sensor flex cable: passo 3, immagine 3 di 3
      • Lay the watch face down.
      • Carefully lift the back cover up from the edge with the buttons to access the sensor connector.
      • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    4. Core Assembly Removal, Remove the back cover: passo 4, immagine 1 di 2 Core Assembly Removal, Remove the back cover: passo 4, immagine 2 di 2
      • Remove the back cover.
      • Make sure the rubber gasket (marked red) is undamaged. If damaged replace it with a new one during reassembly to maintain proper water resistance.
      Chiedi a FixBot
      Aggiungi Commento
    1. Core Assembly Removal, Unplug the display connector: passo 5, immagine 1 di 2 Core Assembly Removal, Unplug the display connector: passo 5, immagine 2 di 2
      • Use the flat end of a spudger to pry up and disconnect the display flex cable from the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    2. Core Assembly Removal, Loosen the core assembly: passo 6, immagine 1 di 2 Core Assembly Removal, Loosen the core assembly: passo 6, immagine 2 di 2
      • The core's plastic frame fits tightly within the watch's metal housing.
      • Place the corner of the flat end of a spudger in the small opening of the barometric sensor, on the opposite side of the display connector.
      • Twist and tilt the spudger to lever the core assembly out of the metal housing.
      Chiedi a FixBot
      Aggiungi Commento
    3. Core Assembly Removal, Remove the core assembly: passo 7, immagine 1 di 3 Core Assembly Removal, Remove the core assembly: passo 7, immagine 2 di 3 Core Assembly Removal, Remove the core assembly: passo 7, immagine 3 di 3
      • Carefully thread the display flex cable through the gap on the core's plastic frame.
      • Remove the core assembly.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Tobias Isakeit
Membro da: 03/31/14
134.940 Reputazione
189 guide realizzate
Tobias Isakeit - Repairability Engineer Membro di Tobias Isakeit - Repairability Engineer
Business
Membro di 1
1.709 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 16
Ultimi 30 giorni: 64
Tutti i Tempi: 1,698
