Salta al contenuto principale
Controller Plate/Buttons Replacement
Cosa ti serve
  1. Controller Plate/Buttons Replacement, Controller Plate/Buttons Replacement: passo 1, immagine 1 di 1
    • Follow the Prerequisite Guide on how to Replace the Battery to prepare the phone for disassemble. Remove, but do not replace the battery.
    Chiedi a FixBot
    Aggiungi Commento
  2. Controller Plate/Buttons Replacement: passo 2, immagine 1 di 1
    • Remove all screws on the plastic case with a T6 Torx T-4 screwdriver, as shown.
    • Blue Circle: T6 Torx, Length 5mm
    • Red Circle: T6 Torx, Length 4mm
    • The screen and other parts are now loose and can easily fall off.
    Chiedi a FixBot
    Aggiungi Commento
  3. Controller Plate/Buttons Replacement: passo 3, immagine 1 di 1
    • Separate the back cover from the phone. A plastic removal tool can be used here.
    Chiedi a FixBot
    Aggiungi Commento
  4. Controller Plate/Buttons Replacement: passo 4, immagine 1 di 1
    • Remove the last two screws holding the motherboard to the device.
    • Orange Circle: 00 Philips head, Length 2 mm
    Chiedi a FixBot
    Aggiungi Commento
  5. Controller Plate/Buttons Replacement: passo 5, immagine 1 di 1
    • Gently pull up the motherboard. Some force may need to be applied.
    • Some wires on the reverse side are still attached.
    • Make sure to line up the plastic connectors highlighted by the red circles when re-assembling.
    Chiedi a FixBot
    Aggiungi Commento
  6. Controller Plate/Buttons Replacement: passo 6, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    • Break the break the data cable connection between the motherboard and the controller plate by gently pulling out the connecting wire with tweezers.
    • When the device is orientated as shown in the picture, apply the force parallel to the motherboard and away from the device, as depicted by the red arrows.
    Chiedi a FixBot
    Aggiungi Commento
  7. Controller Plate/Buttons Replacement: passo 7, immagine 1 di 1
    • The entire controller plate should now be free from the phone. All the buttons can now be taken off by gently pressing them out.
    • If the touch-pad joysticks do not work, the entire plate needs to be replaced.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 59
Tutti i Tempi: 1,844
