Salta al contenuto principale
Contixo V9 Battery Replacement
Cosa ti serve
  1. Contixo V9 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Begin by separating the screen and frame of the device by inserting two prying tools and applying enough pressure until the screen "pops" apart.
  2. Contixo V9 Battery Replacement: passo 2, immagine 1 di 1
    • Use the spudger tool to separate the battery from metal screen frame.
    • There is a small strip of double-sided tape holding it in place.
  3. Contixo V9 Battery Replacement: passo 3, immagine 1 di 1
    • Touch the pre-heated soldering tool to the red and black wire connection points to melt the solder and remove the battery.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 101
