Introduzione
Da qualche parte hai una collana rotta che proprio non riesci a buttare? Questa semplice guida ti permetterà in brevissimo tempo di poterla nuovamente indossare.
Cosa ti serve
Metti alla prova la chiusura tirando delicatamente le due parti appena assemblate. Se si riapre ripeti i passi 4 e 5.
Omg! Thank you. Literally I was so sad that my necklace broke cos it was of my favourite band. Thank you
Jewelers newer use the needle nose pliers to fix the chain. Unless to put the needle thru the chain link and push inside to open that chain link. They use any different but not needle nose- to squeeze the links back. Best way- to twist the link by two pliers ( not needle nose!!) put thru the chain link and twist it back.
Ora sei pronto a sfoggiare nuovamente la tua vecchia collana!
Altre 37 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
14 Commenti
My chain broke when my 7 year old cousin pulled on it when he was piggy back ridding me. Ha Ha. Only took 20 min to do this. Very easy bit best to have nimble and dexterous fingers
With the smaller necklaces, the broken link always falls off really easily, is there a way to make that easier to fix?
My costly gold chain break down...as it is very lin... How can I joint it
I would like to say that my gold chain down due to its thinness...how can I joint this chain
A link broke in my dogs chain collar. I'm using needle nose pliers, but I can't get the two ends of the open link to line up so I can close it!! I've never had this problem before!
This is so hard to do. I can’t even put the links together.
I acsadently broke my necklace
Jayden ayala
I want to say that my gold ring is down due to its thinness... Can you tell me how I can attach this chain?
I am trying to repair a broken chain but I cannot link because the chain is too too small. I cannot correctly grip the rings with the pliers because of the size. HELP
