Salta al contenuto principale
Coby Kyros MID9742 Camera Module Replacement
Cosa ti serve
    1. Coby Kyros MID9742 Camera Module Replacement, Outer Casing: passo 1, immagine 1 di 1
      • Use a spudger to remove the four rubber screw covers from the four back corners of the tablet.
      Chiedi a FixBot
      Aggiungi Commento
    2. Coby Kyros MID9742 Camera Module Replacement: passo 2, immagine 1 di 1
      • Place the PH00 screwdriver and use it to remove the four 0.5 cm screws from each corner of the tablet.
      Chiedi a FixBot
      Aggiungi Commento
    3. Coby Kyros MID9742 Camera Module Replacement: passo 3, immagine 1 di 1
      • Place a metal spudger tool in between the front and back panels of the tablet and begin to pry the base from the front panel by moving the metal tool around the perimeter of the tablet.
      • Note that clicking noises will be heard during this process, the panels are assembled well so it may take some force to separate the two panels.
      • Use caution while prying, do not stick the metal spudger in too far as it may damage internal components
      Chiedi a FixBot
      Aggiungi Commento
    1. Coby Kyros MID9742 Camera Module Replacement, Camera Module: passo 4, immagine 1 di 1
      • Remove the two ribbon cables attached to the logic board.
      Chiedi a FixBot
      Aggiungi Commento
    2. Coby Kyros MID9742 Camera Module Replacement: passo 5, immagine 1 di 1
      • Remove the tape covering the ribbon cables and remove the camera module.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Jake
Membro da: 03/11/15
167 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 8
Ultimi 30 giorni: 35
Tutti i Tempi: 467
