Salta al contenuto principale
Casio LK-170 Key Replacement
Cosa ti serve
    1. Casio LK-170 Key Replacement, Key: passo 1, immagine 1 di 3 Casio LK-170 Key Replacement, Key: passo 1, immagine 2 di 3 Casio LK-170 Key Replacement, Key: passo 1, immagine 3 di 3
      • You will be removing 17 11mm screws with a JIS-1 screwdriver to detach the back of the keyboard from the front.
      • You will begin by removing 4 screws on each side of the piano, circled in red.
      • You will then remove the four screws that are a little hidden, circled in orange.
      • Next, remove the two screws in the middle of piano, as well as the three screws on the top of the piano, circled in yellow.
      Chiedi a FixBot
      Aggiungi Commento
    2. Casio LK-170 Key Replacement: passo 2, immagine 1 di 2 Casio LK-170 Key Replacement: passo 2, immagine 2 di 2
      • After flipping the keyboard over to the front, carefully remove the the front panel from the back panel of the keyboard using your hands.
      • You should now see the screws holding the keys in place.
      • There are five 18mm screws per section of keys.
      • With a JIS-1 bit, unscrew the five screws in the section with the key you want to replace.
      Chiedi a FixBot
      Aggiungi Commento
    3. Casio LK-170 Key Replacement: passo 3, immagine 1 di 2 Casio LK-170 Key Replacement: passo 3, immagine 2 di 2
      • You will be able to pick up the white keys with your hands and remove them.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 13-2, Banghart Winter 2017 Membro di Cal Poly, Team 13-2, Banghart Winter 2017
CPSU-BANGHART-W17S13G2
3 Membri
10 guide realizzate
2Commenti sulla guida
This guide also works for the Casio LK-175.
The keys are in small groups and you will need to purchase the correct ones. Unfortunately, the ones I received from a seller did not match. I think he thought the part was compatible between my keyboard and the one he pulled them from. I very carefully tried super-gluing the key back onto it's section and so far so good (a few hours). Hopefully, the repair will hold.
Thank you for the guide Samantha.
Steve Ferrel - Rispondi Condividi
Do you know if this exposes the circuit board(s)? I need to open my Casio LK175 to figure out why it's only working with batteries. I need to test the power adapter with a load...but the easiest way to do that would probably be measuring the voltage on the pins inside the board.
Thanks for posting this BTW. I saw so many screws on the bottom. I figured a lot of em were holding the keys. I was afraid to open it up, because I figured I'd mess it up. This is very helpful!
Heather Hodge - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 12
Ultimi 30 giorni: 52
Tutti i Tempi: 2,983
