Introduzione
Vai al passo 1 ↓If you need to replace the outside casing, follow this guide. The outside casing is essential to keeping everything inside in place, and protecting the internal structures of the device. If there is cosmetic damage or significant disfigurement, replacement of the metal outside casing is suggested. For this guide, you will need the Torx Security T10 Bit Screwdriver as well as the extension bit.
Cosa ti serve
Strumenti
Twist the top plastic container to the left counterclockwise.
Pull upwards to remove.
