Salta al contenuto principale
Canon Vixia HF R62 Speaker Replacement
Cosa ti serve
  1. Canon Vixia HF R62 Speaker Replacement, Outer Shell: passo 1, immagine 1 di 2 Canon Vixia HF R62 Speaker Replacement, Outer Shell: passo 1, immagine 2 di 2
    • Remove the strap by undoing the Velcro and pulling it through the thread points.
    • Remove the external battery pack by pressing down on the slide release and sliding it out.
  2. Canon Vixia HF R62 Speaker Replacement: passo 2, immagine 1 di 2 Canon Vixia HF R62 Speaker Replacement: passo 2, immagine 2 di 2
    • Remove the three 5mm Phillips #000 screws on the bottom of the device.
  3. Canon Vixia HF R62 Speaker Replacement: passo 3, immagine 1 di 2 Canon Vixia HF R62 Speaker Replacement: passo 3, immagine 2 di 2
    • On the side of the device, remove the following Phillips #000 screws:
    • One 3mm screw
    • One 5mm screw
  4. Canon Vixia HF R62 Speaker Replacement: passo 4, immagine 1 di 2 Canon Vixia HF R62 Speaker Replacement: passo 4, immagine 2 di 2
    • Remove the panel opposite the display by pulling up perpendicular to the side.
  5. Canon Vixia HF R62 Speaker Replacement: passo 5, immagine 1 di 1
    • Remove the 4mm Phillips #000 screw that was exposed after taking off the side panel.
  6. Canon Vixia HF R62 Speaker Replacement: passo 6, immagine 1 di 2 Canon Vixia HF R62 Speaker Replacement: passo 6, immagine 2 di 2
    • Remove the three 4mm Phillips #000 screws shown.
    • There will be foam covers protecting some or all of these screws. These will need to be removed before you will be able to unscrew them.
  7. Canon Vixia HF R62 Speaker Replacement: passo 7, immagine 1 di 3 Canon Vixia HF R62 Speaker Replacement: passo 7, immagine 2 di 3 Canon Vixia HF R62 Speaker Replacement: passo 7, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using tweezers, disconnect this ribbon cable by pulling straight out.
  8. Canon Vixia HF R62 Speaker Replacement: passo 8, immagine 1 di 3 Canon Vixia HF R62 Speaker Replacement: passo 8, immagine 2 di 3 Canon Vixia HF R62 Speaker Replacement: passo 8, immagine 3 di 3
    • Repeat step seven (7) for the remaining three wires shown.
  9. Canon Vixia HF R62 Speaker Replacement: passo 9, immagine 1 di 3 Canon Vixia HF R62 Speaker Replacement: passo 9, immagine 2 di 3 Canon Vixia HF R62 Speaker Replacement: passo 9, immagine 3 di 3
    • Grasp the top of the camera and pull straight up to remove the top panel.
  10. Canon Vixia HF R62 Speaker Replacement, Speaker: passo 10, immagine 1 di 1
    • Grab the top panel and flip it upside down.
  11. Canon Vixia HF R62 Speaker Replacement: passo 11, immagine 1 di 2 Canon Vixia HF R62 Speaker Replacement: passo 11, immagine 2 di 2
    • Remove the 4mm Phillips #000 screw from the front side top panel.
  12. Canon Vixia HF R62 Speaker Replacement: passo 12, immagine 1 di 3 Canon Vixia HF R62 Speaker Replacement: passo 12, immagine 2 di 3 Canon Vixia HF R62 Speaker Replacement: passo 12, immagine 3 di 3
    • Remove the other two 4mm Phillips #000 screws from the green chip.
  13. Canon Vixia HF R62 Speaker Replacement: passo 13, immagine 1 di 1
    • Separate the chip from the black plastic part and remove the black plastic part.
  14. Canon Vixia HF R62 Speaker Replacement: passo 14, immagine 1 di 2 Canon Vixia HF R62 Speaker Replacement: passo 14, immagine 2 di 2
    • Remove four 4mm Phillips #000 screws on the top of the metal part.
  15. Canon Vixia HF R62 Speaker Replacement: passo 15, immagine 1 di 2 Canon Vixia HF R62 Speaker Replacement: passo 15, immagine 2 di 2
    • Take off the electronic component.
  16. Canon Vixia HF R62 Speaker Replacement: passo 16, immagine 1 di 2 Canon Vixia HF R62 Speaker Replacement: passo 16, immagine 2 di 2
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 164
