Salta al contenuto principale
Canon PowerShot A460 Back Casing Replacement
Cosa ti serve
  1. Canon PowerShot A460 Back Casing Replacement, Battery: passo 1, immagine 1 di 1
    • Slide the switch on the battery cover labeled "CARD/BATT. OPEN." to the right.
    • While still holding the switch, pull the cover down, allowing it to release and open.
    Chiedi a FixBot
    Aggiungi Commento
  2. Canon PowerShot A460 Back Casing Replacement: passo 2, immagine 1 di 1
    • Tilt the camera slightly to allow the batteries to fall out.
    Chiedi a FixBot
    Aggiungi Commento
  3. Canon PowerShot A460 Back Casing Replacement: passo 3, immagine 1 di 1
    • Press on and release the memory card to eject it.
    Chiedi a FixBot
    Aggiungi Commento
  4. Canon PowerShot A460 Back Casing Replacement, Front Casing: passo 4, immagine 1 di 1
    • Unscrew the 5mm Phillips #00 screw from the bottom of the camera.
    • Make sure to keep the different size screws organized to make reassembling the camera simpler.
    Chiedi a FixBot
    Aggiungi Commento
  5. Canon PowerShot A460 Back Casing Replacement: passo 5, immagine 1 di 1
    • Unscrew the three 2mm Phillips #00 screws that are located on the bottom of the camera.
    Chiedi a FixBot
    Aggiungi Commento
  6. Canon PowerShot A460 Back Casing Replacement: passo 6, immagine 1 di 1
    • Remove the 4mm Phillips #00 screw that is located on the left side of the camera, if the display screen is facing you.
    Chiedi a FixBot
    Aggiungi Commento
  7. Canon PowerShot A460 Back Casing Replacement: passo 7, immagine 1 di 1
    • Take out the 4mm Phillips #00 screw under the rubber flap on the right end of the camera.
    Chiedi a FixBot
    Aggiungi Commento
  8. Canon PowerShot A460 Back Casing Replacement: passo 8, immagine 1 di 2 Canon PowerShot A460 Back Casing Replacement: passo 8, immagine 2 di 2
    • Remove the second battery cover on the bottom of camera.
    • Take the silver battery out of the camera.
    Chiedi a FixBot
    Aggiungi Commento
  9. Canon PowerShot A460 Back Casing Replacement: passo 9, immagine 1 di 3 Canon PowerShot A460 Back Casing Replacement: passo 9, immagine 2 di 3 Canon PowerShot A460 Back Casing Replacement: passo 9, immagine 3 di 3
    • Remove the 4mm Phillips #00 screw on the inside of the flap that hides the battery and memory card slots.
    • Remove the light grey, plastic piece.
    • Remove the plastic portion of the battery flap cover. The metal piece will remain attached.
    Chiedi a FixBot
    Aggiungi Commento
  10. Canon PowerShot A460 Back Casing Replacement: passo 10, immagine 1 di 3 Canon PowerShot A460 Back Casing Replacement: passo 10, immagine 2 di 3 Canon PowerShot A460 Back Casing Replacement: passo 10, immagine 3 di 3
    • Slightly pull on each side of the camera. It should loosen up and come apart.
    • If it does not pull apart right away, use a little more force.
    • Do not give up!
    Chiedi a FixBot
    Aggiungi Commento
  11. Canon PowerShot A460 Back Casing Replacement, Back Casing: passo 11, immagine 1 di 1
    • Remove the back case of the camera by pulling from the top.
    • Be careful when pulling off the case. There is a delicate gold ribbon connecting the bottom of the camera to the back case.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Cal Poly, Team 19-42, Regan Winter 2013 Membro di Cal Poly, Team 19-42, Regan Winter 2013
CPSU-REGAN-W13S19G42
4 Membri
12 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 13
Ultimi 30 giorni: 87
Tutti i Tempi: 4,077
