Salta al contenuto principale
Canon PowerShot A4000 IS Camera Lens Error Troubleshooting
Guida Archiviata
Questa guida è mantenuta solo per scopi storici. Usa la versione aggiornata della guida per eseguire la riparazione.
Cosa ti serve
  1. Canon PowerShot A4000 IS Camera Lens Error Troubleshooting, If there is a Visible Gap in the Lens: passo 1, immagine 1 di 1
    • The first step for a lens error is to gently clean the leans with a clean cloth. If this does not work, then you proceed with the following steps.
    • Apply gentle pressure to the lens cover and move lens in a circular motion until you hear a "click".
  2. Canon PowerShot A4000 IS Camera Lens Error Troubleshooting, If the Menu is Still Accessible: passo 2, immagine 1 di 1
    • Hold down the menu button for at least 10 seconds and select the "Factory Reset" option to reset your lens.
  3. Canon PowerShot A4000 IS Camera Lens Error Troubleshooting, If the Menu is Not Accessible: passo 3, immagine 1 di 1
    • Remove the battery from your camera and replace it once it is fully charged or buy a new battery if your current one is over a year old. See Battery Removal for more details.
    • Once the battery is out, remove the memory card from camera as well. See Memory Card Replacement for more details.
    • Turning the camera on without a memory card will reset the camera. If the camera has been reset and displays a memory card error message, then the memory card can be reinserted and the camera turned on once again.
  4. Canon PowerShot A4000 IS Camera Lens Error Troubleshooting, Changing the Battery Does Not Work: passo 4, immagine 1 di 2 Canon PowerShot A4000 IS Camera Lens Error Troubleshooting, Changing the Battery Does Not Work: passo 4, immagine 2 di 2
    • Insert the A/V cable then plug the cable into a power supply or computer. Please see Connecting Camera to Computer for further instructions.
    • Turn the camera on by pushing the ON/OFF button.
  5. Canon PowerShot A4000 IS Camera Lens Error Troubleshooting, New Batteries Do Not Work: passo 5, immagine 1 di 2 Canon PowerShot A4000 IS Camera Lens Error Troubleshooting, New Batteries Do Not Work: passo 5, immagine 2 di 2
    • While turning the camera on by pushing the ON/OFF button, press and hold the MENU or FUNC. SET button.
Linea Traguardo
Ashley Heslip
Membro da: 10/13/14
309 Reputazione
3 Guide realizzate
Clemson, Team 1-3, Benson Fall 2014 Membro di Clemson, Team 1-3, Benson Fall 2014
CLEM-BENSON-F14S1G3
3 Membri
17 Guide realizzate
2 Commenti
My lens is stuck out and won't go back in it says lens error and that it will shut off automatically what do I do?
trudiaguilar - Replica
I have done all of the above recommendations and my camera still has a lens error and lens won’t open… :-(
Rosie Bird - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 3,685
