Salta al contenuto principale
Canon PowerShot A2500 Buttons Replacement
Cosa ti serve
  1. Canon PowerShot A2500 Buttons Replacement, Body Casing and Faceplate: passo 1, immagine 1 di 2 Canon PowerShot A2500 Buttons Replacement, Body Casing and Faceplate: passo 1, immagine 2 di 2
    • Remove the knot holding the wrist lanyard onto the camera
    Chiedi a FixBot
    Aggiungi Commento
  2. Canon PowerShot A2500 Buttons Replacement: passo 2, immagine 1 di 1
    • Open the latch at the bottom corner of the device to reveal the battery and SD card housing.
    • There is an orange latch holding the battery in place which must be pushed back in order to free the battery.
    • Once the battery is removed push the SD card and this will activate a spring ejecting the card from the camera.
    Chiedi a FixBot
    Aggiungi Commento
  3. Canon PowerShot A2500 Buttons Replacement: passo 3, immagine 1 di 3 Canon PowerShot A2500 Buttons Replacement: passo 3, immagine 2 di 3 Canon PowerShot A2500 Buttons Replacement: passo 3, immagine 3 di 3
    • Remove the 6 Phillips #00 exterior screws from the camera. Two are located on the bottom and two are located on either side as shown. Notice that one of the screws is under the AV Out Digital flap on the side. All exterior screws should be 2.4mm in length
    Chiedi a FixBot
    Aggiungi Commento
  4. Canon PowerShot A2500 Buttons Replacement: passo 4, immagine 1 di 3 Canon PowerShot A2500 Buttons Replacement: passo 4, immagine 2 di 3 Canon PowerShot A2500 Buttons Replacement: passo 4, immagine 3 di 3
    • Pry apart the camera casing using the plastic opening tool tool provided. Once the casing has begun to separate pull the two sides apart with your hands.
    • Be careful not to bend the plastic casing to much, as it will crack.
    Chiedi a FixBot
    Aggiungi Commento
  5. Canon PowerShot A2500 Buttons Replacement, Buttons: passo 5, immagine 1 di 1
    • Remove the single philips #00 screw on the button pad which are 2.2mm long. This screw is circled in red in the guide image.
    • Next, remove the two 2.4mm long screws located in between the LCD screen and the touch pad. These screws will require a Phillips #00 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  6. Canon PowerShot A2500 Buttons Replacement: passo 6, immagine 1 di 2 Canon PowerShot A2500 Buttons Replacement: passo 6, immagine 2 di 2
    • Pull the two clips off located near the power button
    • The clips are easily broken, use care while disconnecting these clips.
    Chiedi a FixBot
    Aggiungi Commento
  7. Canon PowerShot A2500 Buttons Replacement: passo 7, immagine 1 di 3 Canon PowerShot A2500 Buttons Replacement: passo 7, immagine 2 di 3 Canon PowerShot A2500 Buttons Replacement: passo 7, immagine 3 di 3
    • Remove the circuit ribbon connecting the flash to the camera in order to proceed to the next instruction.
    • Carefully pull out the circuit ribbon from the camera which should be the last piece holding the button pad onto the camera.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Jeff
Membro da: 03/12/15
245 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 27
Tutti i Tempi: 1,515
