Salta al contenuto principale
Canon PowerShot A2200 Button Assembly Replacement
Cosa ti serve
    1. Canon PowerShot A2200 Button Assembly Replacement, Back Cover: passo 1, immagine 1 di 1
      • First, remove the batteries and memory card.
      • Remove the 5.0 mm black screw with a Phillips #00 screwdriver.
      • Remove the 5.0 mm silver screw with a Phillips #00 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    2. Canon PowerShot A2200 Button Assembly Replacement: passo 2, immagine 1 di 1
      • Remove the 5.0 mm black screw on the right with a Phillips #00 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    3. Canon PowerShot A2200 Button Assembly Replacement: passo 3, immagine 1 di 1
      • Remove the 5.0 mm screw on the left with a Phillips #00 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    4. Canon PowerShot A2200 Button Assembly Replacement: passo 4, immagine 1 di 3 Canon PowerShot A2200 Button Assembly Replacement: passo 4, immagine 2 di 3 Canon PowerShot A2200 Button Assembly Replacement: passo 4, immagine 3 di 3
      • Begin taking off the back cover with a plastic opening tool.
      • Begin by wedging the plastic opening tool behind the bottom left corner of the LCD screen as shown.
      • Slide the plastic opening tool to the right, along the mating edge, to pry off the back cover.
      • Continue taking off the back cover along the left side of the camera as seen in the third picture.
      Chiedi a FixBot
      Aggiungi Commento
    5. Canon PowerShot A2200 Button Assembly Replacement: passo 5, immagine 1 di 3 Canon PowerShot A2200 Button Assembly Replacement: passo 5, immagine 2 di 3 Canon PowerShot A2200 Button Assembly Replacement: passo 5, immagine 3 di 3
      • Use the plastic opening tool to separate the top section of the back cover from the frame.
      • Once there is enough separation between the back cover and the frame, remove the back cover for replacement.
      Chiedi a FixBot
      Aggiungi Commento
    1. Canon PowerShot A2200 Button Assembly Replacement, Button Assembly: passo 6, immagine 1 di 2 Canon PowerShot A2200 Button Assembly Replacement, Button Assembly: passo 6, immagine 2 di 2
      • Remove the internal 4.4mm screw with a Phillips 00 screwdriver.
      • Make sure you're removing the screw circled in red, not the screw crossed out in orange.
      Chiedi a FixBot
      Aggiungi Commento
    2. Canon PowerShot A2200 Button Assembly Replacement: passo 7, immagine 1 di 1
      • Gently lift of the buttons for replacement. They should come off without excessive force.
      • If the buttons do not lift off easily, you may have unscrewed the wrong screw. Revert to previous step.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Baylor, Team 4-5, Williams Spring 2015 Membro di Baylor, Team 4-5, Williams Spring 2015
BU-WILLIAMS-S15S4G5
4 Membri
13 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 8
Ultimi 30 giorni: 29
Tutti i Tempi: 1,097
