Salta al contenuto principale
Canon PIXMA MP620B USB Reader Replacement
Cosa ti serve
    1. Canon PIXMA MP620B USB Reader Replacement, Pop off right blue side panel: passo 1, immagine 1 di 2 Canon PIXMA MP620B USB Reader Replacement, Pop off right blue side panel: passo 1, immagine 2 di 2
      • Locate the tabs on the top of the panel that hook down and into the black side panel.
      • Insert the Spudger in-between the black panel and the blue panel as shown and pull the two pieces apart.
      • You will hear some snapping. Don't panic: this is just the hooks un-clipping.
      Chiedi a FixBot
      Aggiungi Commento
    2. Canon PIXMA MP620B USB Reader Replacement, Loosen the back panel: passo 2, immagine 1 di 1
      • Remove the two screws from the back right black panel using the Phillips #00 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    3. Canon PIXMA MP620B USB Reader Replacement, Pull off black side panel: passo 3, immagine 1 di 2 Canon PIXMA MP620B USB Reader Replacement, Pull off black side panel: passo 3, immagine 2 di 2
      • There is a tab you will have to push down to remove the part.
      • Once the tab is released, gently lift the cover away from the rest of the device to disengage the clips.
      • You will hear some snapping. Don't panic: this is just the clips un-clipping.
      Chiedi a FixBot
      Aggiungi Commento
    4. Canon PIXMA MP620B USB Reader Replacement, Take off the black side panel: passo 4, immagine 1 di 1
      • After unclipping all the hooks, pull off the black side panel to reveal the inner circuit boards.
      Chiedi a FixBot
      Aggiungi Commento
    5. Canon PIXMA MP620B USB Reader Replacement, Unscrew 2 screws from USB chip: passo 5, immagine 1 di 1
      • Remove the two screws from the USB reader using the Phillips #00 screwdriver.
      • The angle for removing the screws can be somewhat challenging, try not to get too frustrated.
      Chiedi a FixBot
      Aggiungi Commento
    6. Canon PIXMA MP620B USB Reader Replacement, Pull out USB chip and disconnect white wire: passo 6, immagine 1 di 1
      • Disconnect the large white ribbon cable that leads to the USB reader. As you are pulling out the USB reader, carefully detach the ribbon.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team 6-21, Maness Fall 2014 Membro di Cal Poly, Team 6-21, Maness Fall 2014
CPSU-MANESS-F14S6G21
4 Membri
10 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 38
Tutti i Tempi: 1,196
