Salta al contenuto principale
Canon ImageCLASS MF4350d Scanner light Replacement
Cosa ti serve
    1. Canon ImageCLASS MF4350d Scanner light Replacement, Scanner Disassembly: passo 1, immagine 1 di 1
      • If at any point you see glass that seems cracked or broken, handle with care. Broken glass is sharp and can cause serious damage.
      • Lift up the lid. Then be sure to examine the glass. If there are any cracks or broken fragments handle with extreme care.
      Chiedi a FixBot
      Aggiungi Commento
    2. Canon ImageCLASS MF4350d Scanner light Replacement: passo 2, immagine 1 di 3 Canon ImageCLASS MF4350d Scanner light Replacement: passo 2, immagine 2 di 3 Canon ImageCLASS MF4350d Scanner light Replacement: passo 2, immagine 3 di 3
      • Locate the black and white hinges.
      • Gently lift out the black and white hinges.
      Chiedi a FixBot
      Aggiungi Commento
    3. Canon ImageCLASS MF4350d Scanner light Replacement: passo 3, immagine 1 di 3 Canon ImageCLASS MF4350d Scanner light Replacement: passo 3, immagine 2 di 3 Canon ImageCLASS MF4350d Scanner light Replacement: passo 3, immagine 3 di 3
      • Next, locate and remove the four 10mm screws.
      Chiedi a FixBot
      Aggiungi Commento
    4. Canon ImageCLASS MF4350d Scanner light Replacement: passo 4, immagine 1 di 1
      • Gently, pry off the top plate, starting from the back of the printer.
      Chiedi a FixBot
      Aggiungi Commento
    5. Canon ImageCLASS MF4350d Scanner light Replacement: passo 5, immagine 1 di 2 Canon ImageCLASS MF4350d Scanner light Replacement: passo 5, immagine 2 di 2
      • After you have taken off the plate, check to make sure that there is no broken glass. If there is broken glass handle it with gloves. Broken glass, if handled improperly, can cause physical injury.
      Chiedi a FixBot
      Aggiungi Commento
    1. Canon ImageCLASS MF4350d Scanner light Replacement, Scanner light: passo 6, immagine 1 di 3 Canon ImageCLASS MF4350d Scanner light Replacement, Scanner light: passo 6, immagine 2 di 3 Canon ImageCLASS MF4350d Scanner light Replacement, Scanner light: passo 6, immagine 3 di 3
      • Two white tabs are located on the sides of the black component that houses the scanner light. Pull these tabs out, and set them aside.
      • Remove black component by gently pulling it up from the black scanner belt.
      Chiedi a FixBot
      Aggiungi Commento
    2. Canon ImageCLASS MF4350d Scanner light Replacement: passo 7, immagine 1 di 2 Canon ImageCLASS MF4350d Scanner light Replacement: passo 7, immagine 2 di 2
      • When removing the light, you should be careful not to snap the plastic. If you do snap the plastic, handle with gloves and use extreme precaution, because the plastic may be sharp.
      • The light is in the middle of the black component. Remove the light by prying up one side with the plastic opening tool and working your way to the other side of the light.
      • You may hear a snapping sound as the light detaches from the component.
      • Once you have taken out the damaged light, replace it with a new light.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 13-1, Forte Fall 2013 Membro di Cal Poly, Team 13-1, Forte Fall 2013
CPSU-FORTE-F13S13G1
5 Membri
16 guide realizzate
8Commenti sulla guida
While I appreciate the instructions on how to change the scanner bulb, what would be more useful is some info on where to find/buy the actual bulb itself.
I have intensively searched for this item and it appears that Canon does not even sell it, and that unless it also fits another scanner/copier, it is not available at all. Can you comment on this or tell me where I might find one?
tjgraylaw - Rispondi Condividi
here is where you can get them they ship worldwide and you dont need to wait that long.
http://www.coinchange.co.nz/auctions/ele...
timber kitsets - Rispondi Condividi
Unfortunately the www.coinchange.co.nz link is no longer valid. Is there another source for the bulb? Thanks in advance!
bobsbbcards - Rispondi Condividi
I opened up my Canon MF-8580CDW scanner which is the same. As I was putting it back I found two springs laying in the base and cannot find where they go. Can you or anyone help me by telling me where they go? (I know about the belt spring tensioner. This is not that spring)
Bob Johnson - Rispondi Condividi
Was it determined where the springs go? I am having the same issue.
Kevin's Problems - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 34
Tutti i Tempi: 6,713
