Salta al contenuto principale
Canon FS30 Memory Card Replacement
  1. Canon FS30 Memory  Card Replacement, Memory  Card: passo 1, immagine 1 di 2 Canon FS30 Memory  Card Replacement, Memory  Card: passo 1, immagine 2 di 2
    • Locate battery compartment cover. Turn the device over and locate the battery compartment cover.
    • Open Battery Compartment Cover. Place a finger or thumb on the textured section of the battery compartment cover and push forward until you hear a click. Then lift the battery compartment cover.
    Chiedi a FixBot
    Aggiungi Commento
  2. Canon FS30 Memory  Card Replacement: passo 2, immagine 1 di 2 Canon FS30 Memory  Card Replacement: passo 2, immagine 2 di 2
    • Locate the memory card and press it until you hear a click.
    • On removing your finger, the memory card should pop out.
    • Remove the memory card.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
USF Tampa, Team S1-G4, Nance Spring 2017 Membro di USF Tampa, Team S1-G4, Nance Spring 2017
USFT-NANCE-S17S1G4
4 Membri
10 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 16
Tutti i Tempi: 335
