Introduzione
After long term use, it is possible that the flash module on your camera is stuck in position and can only be opened manually, or the light has burnt out. In either case it is safe to say that the module needs to be replaced. Use caution when removing the module because there are several wire harnesses connecting the module to the motherboard.
Cosa ti serve
Place the camera upside down, and position it to where the back of the camera is visible.
Place the camera on its side with the soft touch grip facing up and the top of the camera facing right.
Remove the three black M3x4mm JIS #000 screws on the bottom of the camera.
Remove the following screws from the bottom of the camera:
Two M3x4.5mm JIS #000 screws
One M3x3mm JIS #000 screw
Remove the following screws from around the viewfinder:
One 10mm JIS #00 diopter screw
Two M3x6mm JIS #00 screws
Use a JIS #000 screwdriver to remove the two 3 mm screws on the retention arms. There is one arm on each side of the module.
Remove the Retention Arms.
Altre 2 persone hanno completato questa guida.
