Salta al contenuto principale
Canon EOS 30 LCD Screen Replacement
Cosa ti serve
  1. Canon EOS 30 LCD Screen Replacement, Front Panel: passo 1, immagine 1 di 1
    • Remove the two 4.8 mm black screws above the lens on the front of the camera.
    Chiedi a FixBot
    Aggiungi Commento
  2. Canon EOS 30 LCD Screen Replacement: passo 2, immagine 1 di 1
    • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
    Chiedi a FixBot
    Aggiungi Commento
  3. Canon EOS 30 LCD Screen Replacement: passo 3, immagine 1 di 1
    • Remove the 4.8 mm black screw on the left side of the camera.
    Chiedi a FixBot
    Aggiungi Commento
  4. Canon EOS 30 LCD Screen Replacement: passo 4, immagine 1 di 1
    • Remove the front panel by lifting it away from the camera's body.
    Chiedi a FixBot
    Aggiungi Commento
  5. Canon EOS 30 LCD Screen Replacement, Top Panel: passo 5, immagine 1 di 1
    • Slide the outer eyepiece upward to remove it.
    Chiedi a FixBot
    Aggiungi Commento
  6. Canon EOS 30 LCD Screen Replacement: passo 6, immagine 1 di 1
    • Remove the two 4.75 mm black screws located on the top of the camera.
    Chiedi a FixBot
    Aggiungi Commento
  7. Canon EOS 30 LCD Screen Replacement: passo 7, immagine 1 di 1
    • Remove the four 4.3 mm black screws near the bottom corners of the eyepiece at the back of the camera.
    Chiedi a FixBot
    Aggiungi Commento
  8. Canon EOS 30 LCD Screen Replacement: passo 8, immagine 1 di 2 Canon EOS 30 LCD Screen Replacement: passo 8, immagine 2 di 2
    • Slowly separate the top panel from the camera by pushing it upward.
    • Separating the top panel too far or quickly can damage the ribbon cable and connecting wires that are still attached to the top panel of the camera.
    Chiedi a FixBot
    Aggiungi Commento
  9. Canon EOS 30 LCD Screen Replacement, LCD Screen: passo 9, immagine 1 di 1
    • To unclip gold connector push the edge up and away from the lcd screen. A plastic opening tool is recommended.
    • The gold connector can fall into the camera, but it will remain attached and can be pulled back up.
    Chiedi a FixBot
    Aggiungi Commento
  10. Canon EOS 30 LCD Screen Replacement: passo 10, immagine 1 di 1
    • Lift LCD screen out of mount.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team 8-8, Regan Spring 2011 Membro di Cal Poly, Team 8-8, Regan Spring 2011
CPSU-REGAN-S11S8G8
5 Membri
22 guide realizzate
2Commenti sulla guida
Thank's , your tutorial nice ... gracias
fajar - Rispondi Condividi
Where do you find replacement lcd screen if the one on the camera is cracked?
Jasmine - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 16
Ultimi 30 giorni: 61
Tutti i Tempi: 6,102
