Salta al contenuto principale
Canon A35F Battery Replacement
Cosa ti serve
    1. Canon A35F Battery Replacement, Battery: passo 1, immagine 1 di 1
      • Flip the Canon A35F on its top so that the bottom of the camera is facing up.
      • Spot the two windows on the bottom of the camera (each window has the word "OPEN" written, and an arrow, both pointing the same direction).
      • Use your fingernail (or a iFixit opening tool), and push in the direction of the arrow to open the left compartment.
      Chiedi a FixBot
      Aggiungi Commento
    2. Canon A35F Battery Replacement: passo 2, immagine 1 di 1
      • Wipe the PX-625 mercury battery with a clean cloth, so that there are no unnecessary fingerprints on the battery.
      • Place the mercury battery in the slot with the yellow ribbon.
      • Make sure to place it in the right side! If it is facing the wrong direction, the shutter will be locked and the meter needle will not move to the battery check zone.
      • Make sure not to leave fingerprints on the battery. It may cause corrosion to the camera's electric contact.
      Chiedi a FixBot
      Aggiungi Commento
    3. Canon A35F Battery Replacement: passo 3, immagine 1 di 1
      • Shut the left window close.
      Chiedi a FixBot
      Aggiungi Commento
    4. Canon A35F Battery Replacement: passo 4, immagine 1 di 1
      • Use your fingernail (or a iFixit opening tool), and push in the direction of the arrow to open the right compartment.
      Chiedi a FixBot
      Aggiungi Commento
    5. Canon A35F Battery Replacement: passo 5, immagine 1 di 1
      • Insert the size AA battery, for the flash, into the compartment (make sure to insert the battery in the right direction).
      Chiedi a FixBot
      Aggiungi Commento
    6. Canon A35F Battery Replacement: passo 6, immagine 1 di 1
      • Shut the right window close.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 18
Ultimi 30 giorni: 93
Tutti i Tempi: 6,440
