Salta al contenuto principale
Canon 7210 Fan Replacement
Cosa ti serve
    1. Canon 7210 Fan Replacement, Exterior Shell: passo 1, immagine 1 di 2 Canon 7210 Fan Replacement, Exterior Shell: passo 1, immagine 2 di 2
      • Remove the 4 exterior 9mm Phillips #0 screws. They are located on the sides of the projector.
      Chiedi a FixBot
      Aggiungi Commento
    2. Canon 7210 Fan Replacement: passo 2, immagine 1 di 3 Canon 7210 Fan Replacement: passo 2, immagine 2 di 3 Canon 7210 Fan Replacement: passo 2, immagine 3 di 3
      • Gently lift up on the shell with both hands, from the back to the front.
      • The shell will still be attached by a small cord in the front, so be careful not to tear it loose.
      Chiedi a FixBot
      Aggiungi Commento
    1. Canon 7210 Fan Replacement, Fan: passo 3, immagine 1 di 1
      • Remove the two 7mm Phillips #0 screws that attach the fan to the motherboard of the projector.
      Chiedi a FixBot
      Aggiungi Commento
    2. Canon 7210 Fan Replacement: passo 4, immagine 1 di 1
      • Remove the fan by pulling up gently from the top.
      • Be careful to not pull too hard or quickly, since the fan is still attached to the projector with some other wires.
      Chiedi a FixBot
      Aggiungi Commento
    3. Canon 7210 Fan Replacement: passo 5, immagine 1 di 1
      • Remove the 7mm Phillips #0 screw that fastens the black ground wire connected to the fan and the projector.
      Chiedi a FixBot
      Aggiungi Commento
    4. Canon 7210 Fan Replacement: passo 6, immagine 1 di 1
      • Peel the sticker up on the back of the fan to expose the port where the red, white, and black wires are attached.
      • The wires will need to be cut with small wire cutters in order to completely remove the fan.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
USF Tampa, Team 9-3, Lacy Fall 2016 Membro di USF Tampa, Team 9-3, Lacy Fall 2016
USFT-LACY-F16S9G3
4 Membri
6 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 23
Tutti i Tempi: 600
