Salta al contenuto principale
Brother PT-110 Keypad Contacts Replacement
Cosa ti serve
    1. Brother PT-110 Keypad Contacts Replacement, Batteries: passo 1, immagine 1 di 2 Brother PT-110 Keypad Contacts Replacement, Batteries: passo 1, immagine 2 di 2
      • Push on the side of the cover, and remove it.
      Chiedi a FixBot
      Aggiungi Commento
    2. Brother PT-110 Keypad Contacts Replacement: passo 2, immagine 1 di 1
      • Remove the batteries.
      Chiedi a FixBot
      Aggiungi Commento
    1. Brother PT-110 Keypad Contacts Replacement, Back Plate: passo 3, immagine 1 di 2 Brother PT-110 Keypad Contacts Replacement, Back Plate: passo 3, immagine 2 di 2
      • Unscrew the two 9 mm Phillips #1 screws from the top and bottom.
      • Total: 2 x Screws
      Chiedi a FixBot
      Aggiungi Commento
    2. Brother PT-110 Keypad Contacts Replacement: passo 4, immagine 1 di 1
      • First: To separate the top cover from the body, insert a spudger between the two halves.
      • Gently twist the spudger until the two halves separate. Do this in multiple spots around the perimeter of the cover to distribute the pressure.
      • DO NOT PULL HALVES APART. There are wired connections inside that must be disconnected before halves can be fully separated.
      Chiedi a FixBot
      Aggiungi Commento
    3. Brother PT-110 Keypad Contacts Replacement: passo 5, immagine 1 di 1
      • Gently separate the two covers, ensuring wires are not taut.
      Chiedi a FixBot
      Aggiungi Commento
    4. Brother PT-110 Keypad Contacts Replacement: passo 6, immagine 1 di 1
      • Gently grasp the ribbon wire and top cover, then gently pull the ribbon wire out of its connection.
      Chiedi a FixBot
      Aggiungi Commento
    5. Brother PT-110 Keypad Contacts Replacement: passo 7, immagine 1 di 2 Brother PT-110 Keypad Contacts Replacement: passo 7, immagine 2 di 2
      • Carefully pinch the top of the connector.
      • Pull perpendicular to the device until the wire is disconnected.
      • It may require more force than expected to disconnect the wires.
      Chiedi a FixBot
      Aggiungi Commento
    6. Brother PT-110 Keypad Contacts Replacement: passo 8, immagine 1 di 3 Brother PT-110 Keypad Contacts Replacement: passo 8, immagine 2 di 3 Brother PT-110 Keypad Contacts Replacement: passo 8, immagine 3 di 3
      • Unscrew the three 9 mm Phillips #1 screws shown.
      • Total: 3 x Screws
      Chiedi a FixBot
      Aggiungi Commento
    1. Brother PT-110 Keypad Contacts Replacement, Keypad Contacts: passo 9, immagine 1 di 2 Brother PT-110 Keypad Contacts Replacement, Keypad Contacts: passo 9, immagine 2 di 2
      • Unscrew both 6 mm Phillips #1 screws from the circuit board.
      • Total screws: 2
      Chiedi a FixBot
      Aggiungi Commento
    2. Brother PT-110 Keypad Contacts Replacement: passo 10, immagine 1 di 1
      • Gently lift the circuit board out.
      Chiedi a FixBot
      Aggiungi Commento
    3. Brother PT-110 Keypad Contacts Replacement: passo 11, immagine 1 di 1
      • Peel the keypad contacts up from the plastic casing.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
IUPUI, Team 1-1, Harley Fall 2016 Membro di IUPUI, Team 1-1, Harley Fall 2016
IUPUI-HARLEY-F16S1G1
3 Membri
7 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 23
Tutti i Tempi: 562
