Salta al contenuto principale
Brother PT-1010 Keyboard Replacement
Cosa ti serve
    1. Brother PT-1010 Keyboard Replacement, Remove Back Cover: passo 1, immagine 1 di 1
      • Flip the device over and press down on the indication arrows located at the top center of the back cover and pull it open.
      Chiedi a FixBot
      Aggiungi Commento
    2. Brother PT-1010 Keyboard Replacement: passo 2, immagine 1 di 1
      • Remove batteries, cassette tape, and cutter blade.
      Chiedi a FixBot
      Aggiungi Commento
    3. Brother PT-1010 Keyboard Replacement, Remove Screws: passo 3, immagine 1 di 1
      • Use a phillips size #00 screwdriver to unscrew the 5 corner screws circled in the picture.
      Chiedi a FixBot
      Aggiungi Commento
    4. Brother PT-1010 Keyboard Replacement, Separate Device: passo 4, immagine 1 di 1
      • Separate the top of the device from the bottom. Be very cautious when you separate the device, there is a ribbon attaching the top to the bottom.
      Chiedi a FixBot
      Aggiungi Commento
    5. Brother PT-1010 Keyboard Replacement, Remove side panels: passo 5, immagine 1 di 1
      • Remove the two black side panels. They will easily fall out so just move them to the side until you are putting your device back together.
      Chiedi a FixBot
      Aggiungi Commento
    6. Brother PT-1010 Keyboard Replacement, Pull Ribbon Out: passo 6, immagine 1 di 3 Brother PT-1010 Keyboard Replacement, Pull Ribbon Out: passo 6, immagine 2 di 3 Brother PT-1010 Keyboard Replacement, Pull Ribbon Out: passo 6, immagine 3 di 3
      • Using your index finger and thumb, pull out the golden ribbon from the green circuit board.
      Chiedi a FixBot
      Aggiungi Commento
    7. Brother PT-1010 Keyboard Replacement, Remove Screws from Circuit Board: passo 7, immagine 1 di 1
      • Use a phillips size #00 screwdriver to remove the two screws, circled in red, from the green circuit board.
      Chiedi a FixBot
      Aggiungi Commento
    8. Brother PT-1010 Keyboard Replacement, Remove Circuit Board: passo 8, immagine 1 di 1
      • Carefully remove the green circuit board by pulling it straight up. Be careful not to break the LCD cable ribbon that connects the circuit board to the device.
      • The ribbon is very fragile so be careful to break it when pulling up on the circuit board.
      Chiedi a FixBot
      Aggiungi Commento
    9. Brother PT-1010 Keyboard Replacement, Peel Off Rubber Keyboard: passo 9, immagine 1 di 3 Brother PT-1010 Keyboard Replacement, Peel Off Rubber Keyboard: passo 9, immagine 2 di 3 Brother PT-1010 Keyboard Replacement, Peel Off Rubber Keyboard: passo 9, immagine 3 di 3
      • Underneath the circuit board you will find the rubber keyboard. Peel this off and remove it from the device.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Haley Sweet
Membro da: 10/30/14
460 Reputazione
4 guide realizzate
Baylor, Team 4-4, Williams Fall 2014 Membro di Baylor, Team 4-4, Williams Fall 2014
BU-WILLIAMS-F14S4G4
4 Membri
4 guide realizzate
3Commenti sulla guida
Hi!
Thanks for this very helpful and detailed set of instructions. One small suggestion - assuming that replacing the keyboard means you need a working one to replace the old one with, you might want to consider adding “Parts: replacement keyboard” instead of “No parts required.”
Cheers,
Maria B
Maria Bitterli - Rispondi Condividi
Please specify what is being replaced. Is the rubber keyboard the part that needs to be replaced?
Sincere Cavalier - Rispondi Condividi
Screen is dull, what to do
Judy Baranczyk - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 13
Ultimi 30 giorni: 33
Tutti i Tempi: 3,651
