Salta al contenuto principale
Brother CS6000i Sewing Light Replacement
Cosa ti serve
  1. Brother CS6000i Sewing Light Replacement, Body: passo 1, immagine 1 di 2 Brother CS6000i Sewing Light Replacement, Body: passo 1, immagine 2 di 2
    • Remove the five 20 mm Phillips #2 screws on the back of the device.
    • Remove the single 28 mm Phillips #2 screw on the back of the device.
    • Remove the single 23 mm Phillips #2 screw on the back of the device.
  2. Brother CS6000i Sewing Light Replacement: passo 2, immagine 1 di 2 Brother CS6000i Sewing Light Replacement: passo 2, immagine 2 di 2
    • Pull the white cover off.
  3. Brother CS6000i Sewing Light Replacement: passo 3, immagine 1 di 2 Brother CS6000i Sewing Light Replacement: passo 3, immagine 2 di 2
    • Remove the final screw, a 11 mm Phillips #2.
    • After removing all eight screws, you will have five 2 mm screws, one 28 mm screw, one 23 mm screw, and one 11 mm screw, all of which are Phillips #2.
  4. Brother CS6000i Sewing Light Replacement: passo 4, immagine 1 di 3 Brother CS6000i Sewing Light Replacement: passo 4, immagine 2 di 3 Brother CS6000i Sewing Light Replacement: passo 4, immagine 3 di 3
    • Slightly pull apart the two halves of the machine, taking care not to strain the attached cables.
    • Unhook the white wires that are connected to the motherboard.
    • Fully separate the two halves.
  5. Brother CS6000i Sewing Light Replacement, Sewing Light: passo 5, immagine 1 di 1
    • Use a Phillips #2 screwdriver to remove the single 16 mm Phillips #2 screw.
    • Remove the metal plate.
  6. Brother CS6000i Sewing Light Replacement: passo 6, immagine 1 di 1
    • Use a Phillips #2 screwdriver to remove the two 16 mm Phillips #2 screws.
    • Remove the metal plate underneath screws once screws are removed.
  7. Brother CS6000i Sewing Light Replacement: passo 7, immagine 1 di 1
    • Use a standoff tip to remove the 10 mm Phillips #2 screw directly next to the lightbulb.
  8. Brother CS6000i Sewing Light Replacement: passo 8, immagine 1 di 1
    • Disconnect the light connector from the PCB.
  9. Brother CS6000i Sewing Light Replacement: passo 9, immagine 1 di 1
    • Remove the light.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Aidan Lear
Membro da: 10/31/24
130 Reputazione
1 Guida realizzata
Cuesta, Team 20-1, Krynen Fall 2024 Membro di Cuesta, Team 20-1, Krynen Fall 2024
CUESTA-KRYNEN-F24S20G1
5 Membri
8 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 24
Tutti i Tempi: 215
