Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Boxee Box, usa il nostro manuale di assistenza.
  1. Boxee Box Teardown, Boxee Box Teardown: passo 1, immagine 1 di 3 Boxee Box Teardown, Boxee Box Teardown: passo 1, immagine 2 di 3 Boxee Box Teardown, Boxee Box Teardown: passo 1, immagine 3 di 3
    • Ladies and gentlemen, iFixit is proud to present the Boxee Box by D-Link.
    • It's hard to ignore how much taller the Boxee Box is than the Apple TV and Logitech Revue. This half-sunken cube will definitely stand out in your entertainment system.
    • Yet, we feel that the Box has build quality that rivals Apple's, and is much more solid-looking than the Revue. The front panel is made of glass sturdy plastic and displays a Boxee logo once you power on the device.
    Chiedi a FixBot
    Aggiungi Commento
  2. Boxee Box Teardown: passo 2, immagine 1 di 2 Boxee Box Teardown: passo 2, immagine 2 di 2
    • The Boxee Box looks huge when compared to the Apple TV, but it's really not that cumbersome in real life -- the Apple TV is just teeny tiny.
    • The Box' remote is only a tad bigger, but features a Qwerty keyboard that would come oh-so-handy on the Apple TV. Otherwise, spelling out "the lonely island" takes a while on YouTube.
    • It does remind us of a certain other Apple product, though...
    Chiedi a FixBot
    Aggiungi Commento
  3. Boxee Box Teardown: passo 3, immagine 1 di 2 Boxee Box Teardown: passo 3, immagine 2 di 2
    • We had to peel off Boxee's lime-green rubber base and the adhesive sheet underneath to expose four #1 Phillips and two #2 Phillips screws.
    • The #2 Phillips screws are clearly visible when you peel off the rubber base.
    • The #1 Phillips are recessed, so you'll need a screwdriver with a longer shaft to access them.
    Chiedi a FixBot
    Aggiungi Commento
  4. Boxee Box Teardown: passo 4, immagine 1 di 1
    • The bottom cover of the Boxee Box pulls off fairly easily, exposing all of its boxy goodness.
    • The Boxee Box gives us everything we want, and nothing we don't need:
    • HDMI out
    • Optical and analog (RCA) audio out
    • Ethernet
    • Two USB ports
    • The RCA jacks are a great addition for people who want to hook up the Boxee directly to computer speakers or retro stereo equipment.
    Chiedi a FixBot
    Aggiungi Commento
  5. Boxee Box Teardown: passo 5, immagine 1 di 2 Boxee Box Teardown: passo 5, immagine 2 di 2
    • A single #1 Phillips screw and a bunch of plastic clips hold the front panel to the side of the Boxee Box.
    • The front panel can be detached by disconnecting the connector for the status panel.
    Chiedi a FixBot
    Aggiungi Commento
  6. Boxee Box Teardown: passo 6, immagine 1 di 3 Boxee Box Teardown: passo 6, immagine 2 di 3 Boxee Box Teardown: passo 6, immagine 3 di 3
    • A little bit of prying and the status panel can be removed from the front panel.
    • A soft white plate on the status panel disperses the light from a couple LEDs to illuminate the semi-transparent Boxee logo either orange (standby) or green (running).
    Chiedi a FixBot
    Aggiungi Commento
  7. Boxee Box Teardown: passo 7, immagine 1 di 3 Boxee Box Teardown: passo 7, immagine 2 di 3 Boxee Box Teardown: passo 7, immagine 3 di 3
    • The Boxee Box' wireless board is secured to the metal frame by more Phillips screws.
    • It certainly is refreshing to see common screw types in electronics. When you don't need special tools to repair devices, it's easier to fix it yourself.
    • The wireless board is held on by a data connector and a couple antenna cables.
    Chiedi a FixBot
    Aggiungi Commento
  8. Boxee Box Teardown: passo 8, immagine 1 di 3 Boxee Box Teardown: passo 8, immagine 2 di 3 Boxee Box Teardown: passo 8, immagine 3 di 3
    • The wireless card assembly is composed of a Mini PCI-E wireless card and an interconnect board where the cable from the motherboard is connected.
    • On the back side of the interconnect board we found a Nordic Semiconductor NRF24LU1P transceiver.
    • This chip is most likely used to decode signals received from the awesome QWERTY wireless remote.
    • We recently found the same chip in the Boxee's direct competitor, the Logitech Revue.
    • The Mini PCI-E wireless card employs a Broadcom BCM4319XKUBG.
    • An remote control antenna is printed into the interconnect board right below the Mini PCI-E socket. This is positioned near the top of the device when it is assembled to aid in remote control reception.
    Chiedi a FixBot
    Aggiungi Commento
  9. Boxee Box Teardown: passo 9, immagine 1 di 3 Boxee Box Teardown: passo 9, immagine 2 di 3 Boxee Box Teardown: passo 9, immagine 3 di 3
    • Next come the dual USB ports, which are mounted on a small PCB.
    • The PCB is connected by two #1 Phillips screws, as well as a connector that runs to the motherboard.
    • A thorough USB board analysis reveals a 220 μF capacitor, a PTC Fuse to protect against faulty USB devices, ESD Protection hardware (Clamp diodes and series inductors), and two USB sockets.
    Chiedi a FixBot
    Aggiungi Commento
  10. Boxee Box Teardown: passo 10, immagine 1 di 3 Boxee Box Teardown: passo 10, immagine 2 di 3 Boxee Box Teardown: passo 10, immagine 3 di 3
    • We progress by removing the fan and heatsink assembly from the CPU. It's time to find out what makes this baby tick.
    • Instead of using thermal paste, the Boxee Box uses a phase-change thermal pad much like the one found on the heat sink of the Logitech Revue.
    Chiedi a FixBot
    Aggiungi Commento
  11. Boxee Box Teardown: passo 11, immagine 1 di 3 Boxee Box Teardown: passo 11, immagine 2 di 3 Boxee Box Teardown: passo 11, immagine 3 di 3
    • A couple strips of EMI tape and a few more Phillips screws hold a very triangular power board in place.
    • The tape is most likely placed around the exposed circuits to eliminate audio interference from the power conversion process.
    Chiedi a FixBot
    Aggiungi Commento
  12. Boxee Box Teardown: passo 12, immagine 1 di 2 Boxee Box Teardown: passo 12, immagine 2 di 2
    • What do you find inside of an oddly-shaped device? An oddly-shaped power board, of course.
    • On this board we find:
    • Texas Instruments TPS51116 DC/DC Controller
    • This board is most likely used to convert the 12V received from the power adapter into the voltages used by the motherboard and all the accessory boards.
    Chiedi a FixBot
    Aggiungi Commento
  13. Boxee Box Teardown: passo 13, immagine 1 di 3 Boxee Box Teardown: passo 13, immagine 2 di 3 Boxee Box Teardown: passo 13, immagine 3 di 3
    • After removing a couple more Phillips screws, the motherboard can be removed from the rest of the metal frame.
    • Once it's lifted out, the power button connector is the only thing keeping us from getting a closer look at the board.
    • Once the motherboard is out, the bottom metal frame can be removed from the plastic outer casing.
    • The power button switch and dual antennas are mounted to the bottom metal frame, making it one compact unit.
    Chiedi a FixBot
    Aggiungi Commento
  14. Boxee Box Teardown: passo 14, immagine 1 di 2 Boxee Box Teardown: passo 14, immagine 2 di 2
    • After popping off the top metal cover, we find:
    • Intel Atom CE4110 SOC processor
    • Wolfson WM8524G stereo DAC
    • AKM 8137A multi-clock generator
    • Nanya 1035 NT5CB128MCN-CG 512 MB DDR3 SDRAM (1/2 total RAM capacity)
    • RealTek RTL8201N 10/100 Ethernet PHYceiver
    • FE1.1 USB 2.0 HUB LG3A924A6180
    Chiedi a FixBot
    Aggiungi Commento
  15. Boxee Box Teardown: passo 15, immagine 1 di 1
    • The other side of the motherboard:
    • Toshiba NF3662 TC58NVG3S0ETA00 1 GB NAND Flash
    • LB TS21C HF 1031S
    • Microchip PIC24FJ64GA004-I/PT 16-bit microcontroller
    • Nanya NT5CB128M8CN-CG 512 MB DDR3 SDRAM (1/2 total RAM capacity)
    Chiedi a FixBot
    Aggiungi Commento
  16. Boxee Box Teardown: passo 16, immagine 1 di 3 Boxee Box Teardown: passo 16, immagine 2 di 3 Boxee Box Teardown: passo 16, immagine 3 di 3
    • The Boxee Box's remote is very impressive. The front side has a basic directional pad with a select button in addition to separate play and menu buttons.
    • Instead of employing a full-sized keyboard like the Logitech Revue, Boxee Box engineers cleverly applied a mini QWERTY keyboard to the backside of the remote.
    • When we cracked the remote control open, we discovered a Nordic Semi NRF24LE1 for wireless connectivity to the Nordic Semi NRF24LU1P transceiver attached to the wireless interconnect board.
    • These are the same two chips found in the Logitech Revue's wireless transmitter and receiver circuits.
    Chiedi a FixBot
    Aggiungi Commento
  17. Boxee Box Teardown: passo 17, immagine 1 di 2 Boxee Box Teardown: passo 17, immagine 2 di 2
    • Boxee Box Repairability: 7 out of 10 (10 is easiest to repair)
    • The Boxee has a separate power board that can be replaced independently from the motherboard, should it ever fail.
    • All Phillips screws were used inside the device, requiring you to have just one screwdriver.
    • Once inside, all components come apart pretty logically.
    • The green rubber bottom of the Boxee Box is difficult to remove, and will never look the same once you've removed it.
    Chiedi a FixBot
    Aggiungi Commento
6Commenti sulla guida
Was this a production board? What's with the rework at R12 (bottom left of the Atom, towards the ethernet port)? And the damaged-looking U707 IC (above center of Atom just below DIL socket)?
Hugo Vincent - Rispondi Condividi
At Step 14 you can see an addition to R12 (at the HDMI port).
The little Diode looks like a last second EMI precaution.
It would be interesting to know if it is properly soldered.
Spunkhart - Rispondi Condividi
One of my capacitors in step 12 overheated and is leaking. This has broken my boxee, can anyone help me find the exact capacitor I should order?
Thank you,
Jamie
jamie radcliffe - Rispondi Condividi
I take it that the memory in this unit is not upgradeable? Would be nice to refresh this box that is getting long in the tooth.
Josh Smith - Rispondi Condividi
just came from Best Buy. Went there on a whim and fell on a streaming media universal remote by RCA. Paid $2.99 + tax. Bought it of course for my Boxee. Hope it works. Package says works with Dlink, Roku etc. Now all I need is a power adapter. Anyone know where i can buy a good for a similarly good price
ge - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 14
Ultimi 30 giorni: 53
Tutti i Tempi: 197,383
