Salta al contenuto principale
Bose Soundlink Flex Radiator Replacement
Cosa ti serve
  1. Bose Soundlink Flex Radiator Replacement, Grille: passo 1, immagine 1 di 1
    • Use a heat gun to warm up the device.
    • This will allow for an easier removal of the grille and prevent damage to the device during the replacement. If you do not have access to a heat gun, a hair dryer works as well.
    Chiedi a FixBot
    Aggiungi Commento
  2. Bose Soundlink Flex Radiator Replacement: passo 2, immagine 1 di 1
    • Use an iFixit opening tool to pop off the eight clips on the grille.
    • Be patient and do not rush this process as you may otherwise damage the device.
    Chiedi a FixBot
    Aggiungi Commento
  3. Bose Soundlink Flex Radiator Replacement: passo 3, immagine 1 di 2 Bose Soundlink Flex Radiator Replacement: passo 3, immagine 2 di 2
    • Once the clips have been released, the only thing holding the grille on is glue.
    • Apply minimal force and the grille should pop right off the device.
    • Reheat the device to warm up the glue if there is difficulty in removing.
    Chiedi a FixBot
    Aggiungi Commento
  4. Bose Soundlink Flex Radiator Replacement, Radiator: passo 4, immagine 1 di 3 Bose Soundlink Flex Radiator Replacement, Radiator: passo 4, immagine 2 di 3 Bose Soundlink Flex Radiator Replacement, Radiator: passo 4, immagine 3 di 3
    • Remove the four 2.3 mm screws holding the driver in place using a TR8 Torx screwdriver.
    • Lift the driver out, being cautious of the wires still connected to the device.
    Chiedi a FixBot
    Aggiungi Commento
  5. Bose Soundlink Flex Radiator Replacement: passo 5, immagine 1 di 2 Bose Soundlink Flex Radiator Replacement: passo 5, immagine 2 di 2
    • Remove the six 2.3 mm screws around the edge with a TR8 Torx screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  6. Bose Soundlink Flex Radiator Replacement: passo 6, immagine 1 di 3 Bose Soundlink Flex Radiator Replacement: passo 6, immagine 2 di 3 Bose Soundlink Flex Radiator Replacement: passo 6, immagine 3 di 3
    • Pull the backplate off to expose both sides of the radiator.
    Chiedi a FixBot
    Aggiungi Commento
  7. Bose Soundlink Flex Radiator Replacement: passo 7, immagine 1 di 3 Bose Soundlink Flex Radiator Replacement: passo 7, immagine 2 di 3 Bose Soundlink Flex Radiator Replacement: passo 7, immagine 3 di 3
    • Remove the four 2.3 mm corner screws using a TR8 Torx screwdriver.
    • Remove the two 1.7 mm screws using a TR6 Torx screwdriver.
    • Follow this step for both radiators.
    Chiedi a FixBot
    Aggiungi Commento
  8. Bose Soundlink Flex Radiator Replacement: passo 8, immagine 1 di 2 Bose Soundlink Flex Radiator Replacement: passo 8, immagine 2 di 2
    • Remove the radiator and replace with the new radiator.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Monica Silva
Membro da: 03/19/24
262 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 11
Ultimi 30 giorni: 52
Tutti i Tempi: 976
