Salta al contenuto principale
Bose Soundlink Flex Driver Replacement
Cosa ti serve
  1. Bose Soundlink Flex Driver Replacement, Grille: passo 1, immagine 1 di 1
    • Use a heat gun to warm up the device.
    • This will allow for an easier removal of the grille and prevent damage to the device during the replacement. If you do not have access to a heat gun, a hair dryer works as well.
    Chiedi a FixBot
    Aggiungi Commento
  2. Bose Soundlink Flex Driver Replacement: passo 2, immagine 1 di 1
    • Use an iFixit opening tool to pop off the eight clips on the grille.
    • Be patient and do not rush this process as you may otherwise damage the device.
    Chiedi a FixBot
    Aggiungi Commento
  3. Bose Soundlink Flex Driver Replacement: passo 3, immagine 1 di 2 Bose Soundlink Flex Driver Replacement: passo 3, immagine 2 di 2
    • Once the clips have been released, the only thing holding the grille on is glue.
    • Apply minimal force and the grille should pop right off the device.
    • Reheat the device to warm up the glue if there is difficulty in removing.
    Chiedi a FixBot
    Aggiungi Commento
  4. Bose Soundlink Flex Driver Replacement, Driver: passo 4, immagine 1 di 3 Bose Soundlink Flex Driver Replacement, Driver: passo 4, immagine 2 di 3 Bose Soundlink Flex Driver Replacement, Driver: passo 4, immagine 3 di 3
    • Remove the four 2.3 mm screws holding the driver in place using a TR8 Torx screwdriver.
    • Lift the driver out, being cautious of the wires still connected to the device.
    Chiedi a FixBot
    Aggiungi Commento
  5. Bose Soundlink Flex Driver Replacement: passo 5, immagine 1 di 3 Bose Soundlink Flex Driver Replacement: passo 5, immagine 2 di 3 Bose Soundlink Flex Driver Replacement: passo 5, immagine 3 di 3
    • Remove the six 2.3 mm screws around the edge with a TR8 Torx screwdriver.
    • Pull the back panel off exposing the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  6. Bose Soundlink Flex Driver Replacement: passo 6, immagine 1 di 2 Bose Soundlink Flex Driver Replacement: passo 6, immagine 2 di 2
    • Desolder the joints that are connecting the speaker to the motherboard.
    • Solder the new speaker with the wire color in the same order.
    • Be cautious when removing and adding the solder to not damage the motherboard or burn yourself.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Kalvin Lee
Membro da: 03/19/24
625 Reputazione
3 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 21
Ultimi 30 giorni: 118
Tutti i Tempi: 1,808
