Salta al contenuto principale
Bose Soundlink Flex Battery Replacement
Cosa ti serve
  1. Bose Soundlink Flex Battery Replacement, Grille: passo 1, immagine 1 di 1
    • Use a heat gun to warm up the device.
    • This will allow for an easier removal of the grille and prevent damage to the device during the replacement. If you do not have access to a heat gun, a hair dryer works as well.
    Chiedi a FixBot
    Aggiungi Commento
  2. Bose Soundlink Flex Battery Replacement: passo 2, immagine 1 di 1
    • Use an iFixit opening tool to pop off the eight clips on the grille.
    • Be patient and do not rush this process as you may otherwise damage the device.
    Chiedi a FixBot
    Aggiungi Commento
  3. Bose Soundlink Flex Battery Replacement: passo 3, immagine 1 di 2 Bose Soundlink Flex Battery Replacement: passo 3, immagine 2 di 2
    • Once the clips have been released, the only thing holding the grille on is glue.
    • Apply minimal force and the grille should pop right off the device.
    • Reheat the device to warm up the glue if there is difficulty in removing.
    Chiedi a FixBot
    Aggiungi Commento
  4. Bose Soundlink Flex Battery Replacement, Battery: passo 4, immagine 1 di 3 Bose Soundlink Flex Battery Replacement, Battery: passo 4, immagine 2 di 3 Bose Soundlink Flex Battery Replacement, Battery: passo 4, immagine 3 di 3
    • Remove the four 2.3 mm screws holding the driver in place using a TR8 Torx screwdriver.
    • Lift the driver out, being cautious of the wires still connected to the device.
    Chiedi a FixBot
    Aggiungi Commento
  5. Bose Soundlink Flex Battery Replacement: passo 5, immagine 1 di 3 Bose Soundlink Flex Battery Replacement: passo 5, immagine 2 di 3 Bose Soundlink Flex Battery Replacement: passo 5, immagine 3 di 3
    • Remove the six 2.3 mm screws around the edge with a TR8 Torx screwdriver.
    • Pull the back panel off exposing the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  6. Bose Soundlink Flex Battery Replacement: passo 6, immagine 1 di 2 Bose Soundlink Flex Battery Replacement: passo 6, immagine 2 di 2
    • Remove the three 1.7 mm screws from the motherboard using a TR6 Torx screwdriver.
    • Remove the single 1.4 mm screw from the motherboard using a TR5 Torx screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  7. Bose Soundlink Flex Battery Replacement: passo 7, immagine 1 di 3 Bose Soundlink Flex Battery Replacement: passo 7, immagine 2 di 3 Bose Soundlink Flex Battery Replacement: passo 7, immagine 3 di 3
    • Take the motherboard out and take note of the battery attached.
    • Remove the insulation and the solder from the wiring.
    • Be careful not to damage the motherboard. Doing so will create a slew of problems for the speaker.
    • Solder the wires of the new battery onto the motherboard.
    • Be cautious when adding the solder to not damage the motherboard or burn yourself.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 6 persone hanno completato questa guida.
Kalvin Lee
Membro da: 03/19/24
625 Reputazione
3 guide realizzate
1Commento della guida
How do I know which one is the positive and which one is the negative side of my battery connector in soundlink flex ? As I have already removed the old battery only.
SOM SATPATHY - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 13
Ultimi 7 giorni: 93
Ultimi 30 giorni: 461
Tutti i Tempi: 8,339
