Salta al contenuto principale
Bose SoundTouch 20 Screen Replacement
Cosa ti serve
    1. Bose SoundTouch 20  Screen Replacement, Screen: passo 1, immagine 1 di 2 Bose SoundTouch 20  Screen Replacement, Screen: passo 1, immagine 2 di 2
      • Remove the (6) six 1.5 cm Phillips screws holding on the bottom cover of the speaker using a Phillips #0 screwdriver.
      • Lift the cover straight up and set the cover to the side.
      Chiedi a FixBot
      Aggiungi Commento
    2. Bose SoundTouch 20  Screen Replacement: passo 2, immagine 1 di 2 Bose SoundTouch 20  Screen Replacement: passo 2, immagine 2 di 2
      • Gently pull the white ribbon from the connector on the top side of the motherboard.
      • Make sure to pull straight back so you don't bend or damage the ribbon.
      Chiedi a FixBot
      Aggiungi Commento
    3. Bose SoundTouch 20  Screen Replacement: passo 3, immagine 1 di 2 Bose SoundTouch 20  Screen Replacement: passo 3, immagine 2 di 2
      • Remove the (4) four 1.5 cm screws connecting the motherboard to the speaker.
      • Remove the (2) two 1 cm screws connecting the motherboard to the speaker.
      • When lifting the board, be careful of the two ribbons located underneath the board. Don't lift the board straight up, instead tilt it towards the cables. As shown in picture 2.
      Chiedi a FixBot
      Aggiungi Commento
    4. Bose SoundTouch 20  Screen Replacement: passo 4, immagine 1 di 2 Bose SoundTouch 20  Screen Replacement: passo 4, immagine 2 di 2
      • Remove the white cable by pressing on the side of the connector with a tab and pulling backwards.
      Chiedi a FixBot
      Aggiungi Commento
    5. Bose SoundTouch 20  Screen Replacement: passo 5, immagine 1 di 2 Bose SoundTouch 20  Screen Replacement: passo 5, immagine 2 di 2
      • Gently pull the thinner white ribbon located towards the center of the board.
      • Pull straight down to prevent bending or damaging the ribbon.
      • Squeeze the plastic sides of the plug and pull straight down to remove this ribbon.
      • After removing the two ribbons, completely remove the motherboard and set it to the side.
      Chiedi a FixBot
      Aggiungi Commento
    6. Bose SoundTouch 20  Screen Replacement: passo 6, immagine 1 di 2 Bose SoundTouch 20  Screen Replacement: passo 6, immagine 2 di 2
      • To remove the side panel from the speaker, lift the top of the sides from the slots.
      • The sides will be bent up after removing from the slots, they do not come up right away.
      • After completing the previous step, pull gently straight up to remove the side.
      • Repeat on both sides of the speaker.
      Chiedi a FixBot
      Aggiungi Commento
    7. Bose SoundTouch 20  Screen Replacement: passo 7, immagine 1 di 3 Bose SoundTouch 20  Screen Replacement: passo 7, immagine 2 di 3 Bose SoundTouch 20  Screen Replacement: passo 7, immagine 3 di 3
      • Remove the (2) two 1.5 cm screws circled in picture one.
      • Rotate the speaker to its side and remove the (2) two 1.5 cm screws circled in picture 2. Remove these screws on either side of the speaker.
      • After all screws are removed, gently remove the cover from the speaker as shown in picture 3.
      Chiedi a FixBot
      Aggiungi Commento
    8. Bose SoundTouch 20  Screen Replacement: passo 8, immagine 1 di 3 Bose SoundTouch 20  Screen Replacement: passo 8, immagine 2 di 3 Bose SoundTouch 20  Screen Replacement: passo 8, immagine 3 di 3
      • After lifting the cover, you will see two ribbons attaching the cover to the speaker. Gently remove these ribbons by pulling straight down.
      • Make sure to pull the ribbons straight out so you don't bend or damage the ribbon.
      Chiedi a FixBot
      Aggiungi Commento
    9. Bose SoundTouch 20  Screen Replacement: passo 9, immagine 1 di 2 Bose SoundTouch 20  Screen Replacement: passo 9, immagine 2 di 2
      • Place the fully separated cover face down on a surface.
      • Using a star bit screwdriver, remove the (6) six screws circled in picture 1 to release the screen.
      • Gently push out the screen from the front of the cover.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
USF Tampa, Team S11-G3, Passmore Fall 2017 Membro di USF Tampa, Team S11-G3, Passmore Fall 2017
USFT-PASSMORE-F17S11G3
4 Membri
16 guide realizzate
2Commenti sulla guida
Hi !
Where can I buy the screen ? I can’t find it anywhere
acp62 - Rispondi Condividi
What symptoms? Is it only the display no longer working or does the whole system not power up?
Siegfried Loeffler - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 10
Ultimi 30 giorni: 70
Tutti i Tempi: 7,162
