Introduzione
Audio buttons not working? This guide will help you replace the button board of the Bose SoundLink Mini II. In order to replace these parts be sure to have the necessary tools that are required and the replacement parts. Use caution when working with a charged battery while removing the circuit boards.
Note: This procedure requires removing and reinstalling the battery, which requires the use of a soldering iron and/or a lot of careful disassembly.
Cosa ti serve
Gently remove the rubber base from speaker by pulling around the edges.
Carefully lift the battery from the side nearest the four gold contact pins, but don't try to fully remove it yet.
Carefully desolder the four wires from the power supply board in order to completely detach the battery. There is very little room for the soldering iron without damaging the case or the board; you may want to remove the board first.
For help with soldering, see the soldering guide.
Bose Technicians Instruction Manual: https://riverparkinc.com/wp-content/uplo...
With the battery removed the button board will now be visible.
Altre 5 persone hanno completato questa guida.
6Commenti sulla guida
Hi…is it possible to get a replacement board?
Hi,
What you refer to as the ‘side board’ under step 10… do you know where I can buy one of these from?
Thanks
Steve.
