Salta al contenuto principale
Bosch PS21 Trigger Replacement
Cosa ti serve
    1. Bosch PS21 Trigger Replacement, Battery: passo 1, immagine 1 di 1
      • Pinch the two release tabs on the sides of the battery, and slide the battery out.
      Chiedi a FixBot
      Aggiungi Commento
    1. Bosch PS21 Trigger Replacement, Trigger: passo 2, immagine 1 di 2 Bosch PS21 Trigger Replacement, Trigger: passo 2, immagine 2 di 2
      Strumento utilizzato in questo passaggio:
      $3.99
      • Locate the clip that connects the two halves of the outer casing on the rear edge of the battery shaft. *Use the angled tweezers to remove the clip.
      • Place the tweezers in the groove on the inside of the clip. Use your other hand to firmly brace the drill and pull towards your body until the clip comes loose.
      Chiedi a FixBot
      Aggiungi Commento
    2. Bosch PS21 Trigger Replacement: passo 3, immagine 1 di 3 Bosch PS21 Trigger Replacement: passo 3, immagine 2 di 3 Bosch PS21 Trigger Replacement: passo 3, immagine 3 di 3
      • Locate the eight 5.5 mm screws located on the upwards facing side of the drill.
      • Remove each screw using the T8 Torx driver, set aside in a safe place.
      • After removing all the screws, use a small or medium metal spudger remove the casing to expose the motor and trigger.
      Chiedi a FixBot
      Aggiungi Commento
    3. Bosch PS21 Trigger Replacement: passo 4, immagine 1 di 2 Bosch PS21 Trigger Replacement: passo 4, immagine 2 di 2
      • Place a finger under the metal tab seen here and lift gently up to free the trigger mechanism.
      • Carefully grab the trigger assembly and gently pull upwards without taking too much out of place.
      Chiedi a FixBot
      Aggiungi Commento
    4. Bosch PS21 Trigger Replacement: passo 5, immagine 1 di 2 Bosch PS21 Trigger Replacement: passo 5, immagine 2 di 2
      • Gently disconnect the two wires connecting the motor to the trigger utilizing a pair of pliers.
      • The trigger assembly is Part #:1607233422
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 7 persone hanno completato questa guida.
IUPUI, Team 1-2, Harley Spring 2016 Membro di IUPUI, Team 1-2, Harley Spring 2016
IUPUI-HARLEY-S16S1G2
4 Membri
4 guide realizzate
2Commenti sulla guida
mine has always operated flawlessly, then I was putting a few screws in the bedroom shelf and it worked fine. picked it up to change rotation and it is froze up. the trigger operates the lite and the batteries are fresh. but it will not turn, tried to turn with a wrench but its locked ? motor? gear drive or trigger? It doesn’t even seem as if its trying to turn when you pull the trigger?
roadkingrick - Rispondi Condividi
The most difficult step in this process is disconnecting the black wire from the defective switch. The wire enters the switch block however there is no sign of a screw or fastening one can disconnect to remove that wire! That step is ‘glossed over’. Any enlightenment from anyone would be welcome.
Tony Savage - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 14
Ultimi 30 giorni: 57
Tutti i Tempi: 6,436
