Introduzione
For the updated guide which works on newer Android versions, click here. This guide has been archived for historical purposes.
Android devices, particularly the developer-friendly Nexus models from Google, are especially suited for unlocking and tinkering with.
The Android OS, based upon Linux, is modular enough to allow replacement and upgrading of particular components of the system: bootloader, recovery, radio software, and both the underlying operating system and the user interface. Just as you can replace the default home screen/launcher app with one you like better, you can run a different build of the open source Android operating system (AOSP) for improved performance or bleeding edge capabilities. These are called ROMs.
Even without switching out the core OS, you can use a customized recovery partition. Team Win (TWRP) and ClockworkMod (CWM) are the most popular third party recovery replacements, and are available for many Android devices. They provide advanced maintenance functions, including the ability to install root apps that let the user and apps perform functions as the system user.
Tools
The basic tool for working with a Android device is the Android Software Development Kit (SDK), which includes tools like fastboot and adb (Android Debug Bridge). There are third party "lite" versions of the basic tools for most operating systems. Some GUI tools take the complexity out of using command line tools to perform common operations, but these actions are no less powerful.
Warning
Unlocking, flashing, rooting your device may void the warranty. You are also at risk for "bricking" (rendering inoperable and irreparable) your phone or tablet. You assume full liability and responsibility for attempting to follow any of these steps.
Some applications will not work if a device has been unlocked or rooted. E.g. Android Pay now detects if the system has been compromised this way in Android 6.0, and will refuse to work for you.
Further Information
Google Nexus
- Google Nexus: Using Hardware Devices
- Google Nexus: Booting into fastboot (bootloader)
- ADB Fastboot Install (MacOS, Linux)
XDA developer forums
To power down most phones, hold down the power button until a prompt appears. Tap on the pop-up message. Some devices may have a "Power off" command in the software settings.
If your phone is crashing or locking up after boot, try rebooting into safe mode. In the previous step, tap and hold on "Power off" until the prompt changes to "Reboot to safe mode." Tap OK.
With the phone in an off state, hold down buttons in a combination to enter the bootloader. Google Nexus models have specific combinations like holding Volume Down and Power simultaneously.
Your device's bootloader may look different from this Nexus 5 screen. That's okay. Note the essential information available to you here: phone model, product variant, serial/IMEI number, SIM and bootloader locked state.
The bootloader often displays information like the phone model, version of fastboot, whether or not it is boot-unlocked or not.
For Google Nexus devices, you can now connect your phone to a computer (Windows, MacOS, Linux) running the Android SDK tools, allowing some commands to be sent.
From your bootloader screen, toggling the volume buttons will offer functions like Start, Power Down, Restart Bootloader, and usually … Recovery. Pressing the Power button generally executes the displayed function.
The recovery partition is a rudimentary mini operating mode which allows loading updates, wiping the cache partition, and performing a factory reset to a phone that cannot boot properly (e.g. in an endless bootloop, never reaching an unlock screen). It's not called recovery for no reason -- it's an essential tool for restoring a broken phone.
Congratulations! You now know at least a little more about how to remedy operating system problems with your Android OS phone.
Altre 153 persone hanno completato questa guida.
15 Commenti
i have unlocked the mobile and wiped all logos ,bootloader,system,cache everything and disconnected from pc . and now my phone is not turning on . is there any way to recover it.
Wow, why did you do that?? You've removed the operating system components that your phone needs to run, it should be no surprise that it is bricked. Have you tried to boot into bootloader?
How to recover, if you can, depends upon the model. You'll need to ask a question in the specific topic forum for your phone hardware. If you cannot even boot to the bootloader to run fastboot, you probably need a suitably equipped phone repair shop or factory service center to reflash the phone at the hardware level.
I have rooted my Moto g5 plus phone using magisk and twrp for recovery. It is working perfectly fine with no issues. Then I wanted to do OTA updates. I have backed up my partitions. But I dint have the original partitions. So I flashed boot.img , logo.bin and recovery.img from POTTER_AMZ_7.0_NPNS25.137-35-5_cid18_subsidy-DEFAULT_regulatory-DEFAULT_CFC.xml.zip. firmware. And then rebooted but its stuck in Your device will boot in 5 seconds. Please help
I have rooted my Moto g5 plus using Magisk and twrp for recovery. It was working perfectly fine. I wanted to do OTA updates. I have backed up my partitions. Flashed boot.img, logo.bin and recovery.img from POTTER_AMZ_7.0_NPNS25.137-35-5_cid18_subsidy-DEFAULT_regulatory-DEFAULT_CFC.xml.zip. firmware. Rebooted the phone but its stuck at Your device will boot in 5 seconds. Please help
Sujitha Jose, If you have rooted your Android device and looking out to get the OTA updates, please remove the old magisk installed on your device and install the Magisk Manager Latest Version from the official website http://magisk-manager.com/ as the recent update has got you everything about the OTA updates. You don’t need do anything else.
Thank you, this was really helpful.
Download TWRP Recovery for Samsung Galaxy S7 twrprecoveryapp
I help rooted my Karbonn k9 smart using magisk and twrp for recovery.it was working perfectly fine.i wanted to do OTA updates.i have backed up my partition.flashed boot.img,logo.bin and recovery.img from Potter_AMS_4.4.2/4.0+_NPNS25.137-35_5_cid_18_subsidy_default_regulatory_default_CFC.XML.ZIP.firmwork.robooted the phone but its stuck at your device will boot In 5 seconds.please help.
I have a different problem after a recent misshap my phone is locked in the alcatel loop basicaly the recovery corrupted and it repeats loops in alcatel boot screen is there a solution for this or is it just another paperweight
Specific help on particular models is beyond the (intended) scope of this guide. You can fine more specific information on sites like XDA Developers (as well as people developing custom ROM images for your brand/model of phone.
Not able to unlock bootloader for oppo Reno, anyone can help please?
Hi, did you enable Developer Options from the Settings menu?
Simone -
All of the websites I have seen for re-installing the firmware on Motorola phones use the USB port, which I have found to be unreliable for large file transfers. Someone should find a way to simply put the firmware on a microSD card and use the phone’s Boot From SD Card option.
Actually i used a lot of methods in the past but not able to reach the goal. But this titorial or guide is able to unlock my bootloader in nokia smartphone and now i can do whatever rom i want to insyall as well as diable that $@$* bloatwares and stuff.
Thanks a lot for this help!
