Salta al contenuto principale
Boogie Board Rip Copper Button Plate Replacement
Cosa ti serve
    1. Boogie Board Rip Copper Button Plate Replacement, Accessing the internal components: passo 1, immagine 1 di 2 Boogie Board Rip Copper Button Plate Replacement, Accessing the internal components: passo 1, immagine 2 di 2
      • On the back of the device, remove the four 3/8" Torx head screws using the T-6 Torx bit.
      • A Torx bit is the piece that is inserted into a bit driver, also known as a screw driver.
      Chiedi a FixBot
      Aggiungi Commento
    2. Boogie Board Rip Copper Button Plate Replacement: passo 2, immagine 1 di 3 Boogie Board Rip Copper Button Plate Replacement: passo 2, immagine 2 di 3 Boogie Board Rip Copper Button Plate Replacement: passo 2, immagine 3 di 3
      • Remove the stylus if it is in the housing at the top of the device.
      • Turn the device so you are looking at it from the top down.
      • Using your thumbs on each wall of the stylus housing, open the frame of the device by gently pulling the two sides apart.
      Chiedi a FixBot
      Aggiungi Commento
    3. Boogie Board Rip Copper Button Plate Replacement: passo 3, immagine 1 di 3 Boogie Board Rip Copper Button Plate Replacement: passo 3, immagine 2 di 3 Boogie Board Rip Copper Button Plate Replacement: passo 3, immagine 3 di 3
      • Insert a spudger into the seam between the front and back plates of the frame. Unsnap the snaps around the entire frame of the device.
      • Remove the front face plate by pulling it straight up.
      • The unlock switch on the device's side might come off while undoing the internal snaps or removing the face plate. This is perfectly normal.
      Chiedi a FixBot
      Aggiungi Commento
    4. Boogie Board Rip Copper Button Plate Replacement: passo 4, immagine 1 di 2 Boogie Board Rip Copper Button Plate Replacement: passo 4, immagine 2 di 2
      • Use a spudger (or gently bend the back plate of the device) to unsnap the snaps holding the screen in place.
      Chiedi a FixBot
      Aggiungi Commento
    5. Boogie Board Rip Copper Button Plate Replacement: passo 5, immagine 1 di 2 Boogie Board Rip Copper Button Plate Replacement: passo 5, immagine 2 di 2
      • With a spudger, press against the lip of the connector closest to the wires to remove the battery connector from the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    6. Boogie Board Rip Copper Button Plate Replacement: passo 6, immagine 1 di 2 Boogie Board Rip Copper Button Plate Replacement: passo 6, immagine 2 di 2
      • Gently lift the motherboard with a spudger or small object by inserting it in the seam between the back frame and the motherboard.
      • Remove the battery hidden behind the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    1. Boogie Board Rip Copper Button Plate Replacement, Copper Button Plate: passo 7, immagine 1 di 2 Boogie Board Rip Copper Button Plate Replacement, Copper Button Plate: passo 7, immagine 2 di 2
      Strumento utilizzato in questo passaggio:
      • Using tweezers gently go around the edges of the copper plate to remove the adhesive.
      Chiedi a FixBot
      Aggiungi Commento
    2. Boogie Board Rip Copper Button Plate Replacement: passo 8, immagine 1 di 2 Boogie Board Rip Copper Button Plate Replacement: passo 8, immagine 2 di 2
      • Use tweezers to grip the outer edge of the copper plate and lift the button straight off.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Gareth
Membro da: 09/09/14
360 Reputazione
3 guide realizzate
CSU Fullerton, Team 2-6, Bruce Fall 2014 Membro di CSU Fullerton, Team 2-6, Bruce Fall 2014
CSUF-BRUCE-F14S2G6
4 Membri
6 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 7
Ultimi 30 giorni: 35
Tutti i Tempi: 3,009
