Salta al contenuto principale
Blink Video Doorbell Lens Replacement
Cosa ti serve
  1. Blink Video Doorbell Lens Replacement, Battery: passo 1, immagine 1 di 3 Blink Video Doorbell Lens Replacement, Battery: passo 1, immagine 2 di 3 Blink Video Doorbell Lens Replacement, Battery: passo 1, immagine 3 di 3
    • Push the opening key into the small opening with the two gray buttons on the bottom of the device.
    • The device will click off the mount.
    • Push the device up from the mount and slide it off.
  2. Blink Video Doorbell Lens Replacement: passo 2, immagine 1 di 3 Blink Video Doorbell Lens Replacement: passo 2, immagine 2 di 3 Blink Video Doorbell Lens Replacement: passo 2, immagine 3 di 3
    • Use your finger to slide the gray tab, located near the bottom of the device, upwards.
    • Remove the battery cover.
  3. Blink Video Doorbell Lens Replacement: passo 3, immagine 1 di 3 Blink Video Doorbell Lens Replacement: passo 3, immagine 2 di 3 Blink Video Doorbell Lens Replacement: passo 3, immagine 3 di 3
    • Remove the right battery by pushing the positive end down and pulling the battery out toward yourself.
    • Repeat the procedure for the left battery.
    • Do not mix used and new batteries or batteries of different types (for example, lithium and alkaline batteries).
  4. Blink Video Doorbell Lens Replacement, Back Panel: passo 4, immagine 1 di 3 Blink Video Doorbell Lens Replacement, Back Panel: passo 4, immagine 2 di 3 Blink Video Doorbell Lens Replacement, Back Panel: passo 4, immagine 3 di 3
    • Remove the two 6 mm screws in the battery compartment using a JIS #1 screwdriver.
    • Remove the two 7 mm screws above the battery compartment using a JIS #1 screwdriver.
    • Starting from the bottom of the device, pry the back plate away from the rest of the doorbell.
  5. Blink Video Doorbell Lens Replacement, Lens: passo 5, immagine 1 di 3 Blink Video Doorbell Lens Replacement, Lens: passo 5, immagine 2 di 3 Blink Video Doorbell Lens Replacement, Lens: passo 5, immagine 3 di 3
    • Remove the three 6 mm screws from the upper part of the motherboard using a JIS #1 screwdriver.
    • Use an opening tool to release the motherboard from the device.
  6. Blink Video Doorbell Lens Replacement: passo 6, immagine 1 di 2 Blink Video Doorbell Lens Replacement: passo 6, immagine 2 di 2
    • Carefully lift up the small daughterboard which contains the camera.
    • Remove two 5 mm screws from the back of the camera using a Phillips #0 screwdriver.
  7. Blink Video Doorbell Lens Replacement: passo 7, immagine 1 di 2 Blink Video Doorbell Lens Replacement: passo 7, immagine 2 di 2
    • Use tweezers to detach the white connector from the adapter on the motherboard.
    • Remove the lens.
Conclusione
Kayla Crai
Membro da: 10/18/24
495 Reputazione
4 Guide realizzate
UMass Dartmouth, Team 1-1, Konn Fall 2024 Membro di UMass Dartmouth, Team 1-1, Konn Fall 2024
UMASSD-KONN-F24S1G1
4 Membri
5 Guide realizzate
Un commento
Is it available to purchase the lens
William - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 40
Ultimi 30 Giorni: 126
Tutti i Tempi: 388
