Salta al contenuto principale
Blade Removal Technique
Cosa ti serve
    1. Blade Removal Technique, Blade Removal Technique: passo 1, immagine 1 di 1
      • To remove the blades from each other, twist both blades in opposite directions and pull.
      • Be cautious, the blades are sharp.
      Chiedi a FixBot
      Aggiungi Commento
    2. Blade Removal Technique: passo 2, immagine 1 di 1
      • To remove the blades from the cup. Firmly grasp the bottom of the cup.
      • Be careful when you are doing this next step.
      • Pull upward as shown on the top of the blades.
      Chiedi a FixBot
      Aggiungi Commento
    3. Blade Removal Technique: passo 3, immagine 1 di 1
      • To remove the blades from the motor, firmly grasp the motor top.
      • Next. Take a cloth or cut-resistant glove and grasp the blades.
      • Be careful during this next step.
      • Now twist both ends in opposite directions to separate.
      Chiedi a FixBot
      Aggiungi Commento
Linea Traguardo
USF Tampa, Team 1-3, Sullivan Fall 2015 Membro di USF Tampa, Team 1-3, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G3
3 Membri
15 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 12
Ultimi 30 giorni: 47
Tutti i Tempi: 1,467
