Introduzione
This guide will walk you through how to replace the lens piece on the NetCam.
Cosa ti serve
Use a wrench to loosen up the stand from the back in order to hold the NetCam more comfortably.
Carefully use your fingers to gently pull out the white attachment from the tan colored part.
Use a Phillips #0 screwdriver to take out the two 1.2 mm screws on the board.
Flip the circuit board to the back side.
Fold down the tape with your finger.
With the Phillips #0 screwdriver, unscrew the two 1.2 mm screws.
