Salta al contenuto principale
Beats Studio3 Wireless Battery Replacement
Cosa ti serve
  1. Beats Studio3 Wireless Battery Replacement, Battery: passo 1, immagine 1 di 2 Beats Studio3 Wireless Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Use a pointed nylon spudger to remove the center circular panel on the right side of your device.
    • Be gentle while removing this piece as it is glued on with adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  2. Beats Studio3 Wireless Battery Replacement: passo 2, immagine 1 di 2 Beats Studio3 Wireless Battery Replacement: passo 2, immagine 2 di 2
    • Remove the four 3.5 mm screws using a Phillips #0 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  3. Beats Studio3 Wireless Battery Replacement: passo 3, immagine 1 di 3 Beats Studio3 Wireless Battery Replacement: passo 3, immagine 2 di 3 Beats Studio3 Wireless Battery Replacement: passo 3, immagine 3 di 3
    • Using a pointed nylon spudger, remove the tab located on the inner part of the headband labeled "R."
    • Place the nylon spudger in between the side panels and push inward going from bottom to top to separate both sides of the panel.
    • The panel will pop open after separating.
    Chiedi a FixBot
    Aggiungi Commento
  4. Beats Studio3 Wireless Battery Replacement: passo 4, immagine 1 di 1
    • Place the nylon spudger underneath the battery, push inward and separate the battery from the inside.
    • Never use sharp tools to pry batteries. Metal spudgers can puncture an unprotected battery, potentially causing a fire.
    Chiedi a FixBot
    Aggiungi Commento
  5. Beats Studio3 Wireless Battery Replacement: passo 5, immagine 1 di 2 Beats Studio3 Wireless Battery Replacement: passo 5, immagine 2 di 2
    • Use a nylon spudger to lift up the glue sticking the wires down.
    • Use a nylon spudger to lift the connector to disconnect the battery.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 7 persone hanno completato questa guida.
4Commenti sulla guida
Should the glue be reapplied or is it okay to simply place back on?
Jake Allen - Rispondi Condividi
the replacement batteries usually come with a gluepad on the back.
The connector its up to you - you risk the chance of the connector coming lose and u have to reopen the headset. But ill take the chance for now, lets see how it holds up without new glue.
seb - Rispondi Condividi
Tengo una duda mis audífonos la batería esta full de voltaje pero me marca un rojo y no me prenden q podría ser o que solución podría darle
luis m cruz - Rispondi Condividi
My beats studio 3 proplem was it plink whit when i connect it with the charger, but when i press to start it it blinks full red .
My Qus is .. is the battery are dameged ..?!
Hmam - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 10
Ultimi 7 giorni: 75
Ultimi 30 giorni: 318
Tutti i Tempi: 12,207
