Salta al contenuto principale
Battery disassembly
  1. Battery disassembly, Remove the battery: passo 1, immagine 1 di 3 Battery disassembly, Remove the battery: passo 1, immagine 2 di 3 Battery disassembly, Remove the battery: passo 1, immagine 3 di 3
    • Turn the laptop upside down and gently lay it down on a flat surface.
    • Slide the battery release latch to the right and the battery will pop up slightly.
    • While keeping the latch slid with one hand, grab the battery with the other hand and remove it by pivoting it upward.
    • At this point some users would turn the laptop upside down once again and press the power button a couple of times. They say that this should help dissipating all of the remaining electricity around the device. Up to you :)
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
1Commento della guida
Maybe rename this guide "laptop battery removal" seeing as no dissasembling is taking place.
sephiroth_dk - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 9
Ultimi 30 giorni: 44
Tutti i Tempi: 784
