Salta al contenuto principale
Basis Peak Screen Replacement
Cosa ti serve
    1. Basis Peak Screen Replacement, Frame: passo 1, immagine 1 di 1
      • Flip the watch over and orient it such that the buckle is away from you and the back panel is revealed.
      • Maintain this orientation to follow the guide.
      Chiedi a FixBot
      Aggiungi Commento
    2. Basis Peak Screen Replacement: passo 2, immagine 1 di 2 Basis Peak Screen Replacement: passo 2, immagine 2 di 2
      • Remove the four base screws using a size 2 TORX screwdriver to separate the back plate from the frame.
      Chiedi a FixBot
      Aggiungi Commento
    3. Basis Peak Screen Replacement: passo 3, immagine 1 di 1
      • Disconnect the ribbon cable on the left side of the motherboard by using a spudger.
      Chiedi a FixBot
      Aggiungi Commento
    4. Basis Peak Screen Replacement: passo 4, immagine 1 di 1
      • Use a spudger and apply pressure to the white plastic wall to the right of the motherboard. Use this to lever the electronics out of the frame.
      • The clips have small lips that you can put the spudger under to get more leverage.
      • Using any of the metal to pry out the electronics may damage some of the wiring. It is crucial to only press on the plastic.
      Chiedi a FixBot
      Aggiungi Commento
    1. Basis Peak Screen Replacement, Screen: passo 5, immagine 1 di 1
      • Flip over the motherboard complex and gently remove the screen with your fingers.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Steph
Membro da: 04/06/17
101 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 12
Ultimi 30 giorni: 30
Tutti i Tempi: 549
