Salta al contenuto principale
Basis Peak Battery Replacement
Cosa ti serve
    1. Basis Peak Battery Replacement, Frame: passo 1, immagine 1 di 1
      • Flip the watch over and orient it such that the buckle is away from you and the back panel is revealed.
      • Maintain this orientation to follow the guide.
      Chiedi a FixBot
      Aggiungi Commento
    2. Basis Peak Battery Replacement: passo 2, immagine 1 di 2 Basis Peak Battery Replacement: passo 2, immagine 2 di 2
      • Remove the four base screws using a size 2 TORX screwdriver to separate the back plate from the frame.
      Chiedi a FixBot
      Aggiungi Commento
    3. Basis Peak Battery Replacement: passo 3, immagine 1 di 1
      • Disconnect the ribbon cable on the left side of the motherboard by using a spudger.
      Chiedi a FixBot
      Aggiungi Commento
    4. Basis Peak Battery Replacement: passo 4, immagine 1 di 1
      • Use a spudger and apply pressure to the white plastic wall to the right of the motherboard. Use this to lever the electronics out of the frame.
      • The clips have small lips that you can put the spudger under to get more leverage.
      • Using any of the metal to pry out the electronics may damage some of the wiring. It is crucial to only press on the plastic.
      Chiedi a FixBot
      Aggiungi Commento
    1. Basis Peak Battery Replacement, Motherboard: passo 5, immagine 1 di 1
      • Remove the right side ribbon cable by pulling it off with your fingers.
      Chiedi a FixBot
      Aggiungi Commento
    2. Basis Peak Battery Replacement: passo 6, immagine 1 di 1
      • Use the spudger tool to poke out the exposed motherboard section as seen in the photo.
      • As always be careful when disconnecting the cables or batteries.
      Chiedi a FixBot
      Aggiungi Commento
    3. Basis Peak Battery Replacement: passo 7, immagine 1 di 1
      • Put a nylon spudger underneath the battery's press-fit connector and lift up to free the ribbon cable and motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    1. Basis Peak Battery Replacement, Battery: passo 8, immagine 1 di 1
      • Grip the battery with your fingers and remove it from the plastic.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Dominic Calcasola
Membro da: 03/26/17
101 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 14
Tutti i Tempi: 682
