Salta al contenuto principale
Back Panel
Cosa ti serve
  1. Back Panel, Back Panel: passo 1, immagine 1 di 1
    • Flip the laptop so that the back is facing upwards.
    • Locate the small screw on the back that holds the "L" shaped panel.
    • Using a 0 Phillip Screwdriver (4.0x4.7mm sized screw), unscrew the screw. It will not become detached from the panel but it will allow you to remove the back panel.
    Chiedi a FixBot
    Aggiungi Commento
  2. Back Panel: passo 2, immagine 1 di 3 Back Panel: passo 2, immagine 2 di 3 Back Panel: passo 2, immagine 3 di 3
    • Using a plastic opening tool, pry the back panel from the computer, going all the way around it.
    • This will take a good amount of force and you will hear clicking noises as you snap each of the connections out of place.
    Chiedi a FixBot
    Aggiungi Commento
  3. Back Panel: passo 3, immagine 1 di 1
    • Once the back panel is completely removed you will have access to the RAM and many other connections in the computer.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 39
Tutti i Tempi: 971
