Salta al contenuto principale
Back Cover Replacement
Cosa ti serve
  1. Back Cover Replacement, Back Cover: passo 1, immagine 1 di 1
    • Power off Zoomer Dino Boomer before disassembly.
    • Remove the eight 9.3mm Phillips #1 screws.
    Chiedi a FixBot
    Aggiungi Commento
  2. Back Cover Replacement: passo 2, immagine 1 di 2 Back Cover Replacement: passo 2, immagine 2 di 2
    • Turn dinosaur over and hold upright.
    • Use the spudger to pry apart the back cover from the remainder of the Zoomer Dino Boomer.
    • Be gentle while removing the back cover. The back cover of the Zoomer Dino Boomer is still connected to the electronic system by a wire.
    Chiedi a FixBot
    Aggiungi Commento
  3. Back Cover Replacement: passo 3, immagine 1 di 3 Back Cover Replacement: passo 3, immagine 2 di 3 Back Cover Replacement: passo 3, immagine 3 di 3
    Strumento utilizzato in questo passaggio:
    • Disconnect the wire that connects the back cover of the dino to the main circuit board by carefully pulling on the orange wire connector with tweezers.
    • Remove back cover.
    • If you are having difficulty removing the connector from its socket, push in the small tabs on the side of the connector with the tweezers. This step may take some work.
    • Do not damage the wires or circuit board.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
USF Tampa, Team 16-1, Wollert Fall 2015 Membro di USF Tampa, Team 16-1, Wollert Fall 2015
USFT-WOLLERT-F15S16G1
3 Membri
10 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 29
Tutti i Tempi: 1,063
