Salta al contenuto principale
BLU Studio G Screen Replacement
Cosa ti serve
  1. Attenzione: i passaggi 1-8 provengono da una guida contrassegnata come in corso.
    BLU Studio G Screen Replacement, Motherboard Prerequisite: passo 1, immagine 1 di 3 BLU Studio G Screen Replacement, Motherboard Prerequisite: passo 1, immagine 2 di 3 BLU Studio G Screen Replacement, Motherboard Prerequisite: passo 1, immagine 3 di 3
    • To remove the back cover, turn the device over, locate the safety indented notch on the bottom left corner as the screen is facing down.
    • Using your finger (or spudger), prop upwards to detach the back cover properly from the rest of the device.
    Chiedi a FixBot
    Aggiungi Commento
  2. BLU Studio G Screen Replacement: passo 2, immagine 1 di 2 BLU Studio G Screen Replacement: passo 2, immagine 2 di 2
    • Locate the notch at the bottom of the battery for safe removal.
    • Carefully lift battery from the notch making sure not to puncture the battery rubber casting.
    Chiedi a FixBot
    Aggiungi Commento
  3. BLU Studio G Screen Replacement: passo 3, immagine 1 di 2 BLU Studio G Screen Replacement: passo 3, immagine 2 di 2
    • Unscrew the 13 Phillips #0 screws from the back of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  4. BLU Studio G Screen Replacement: passo 4, immagine 1 di 1
    • To remove the back panel, slide the metal spudger into 3 notches on left and right side outside edges of the device.
    • With some slow but strong pressure insert and dislodge the panel from the rest of the device. These are tough but small clips that hold together the back panel.
    Chiedi a FixBot
    Aggiungi Commento
  5. BLU Studio G Screen Replacement: passo 5, immagine 1 di 2 BLU Studio G Screen Replacement: passo 5, immagine 2 di 2
    • Remove all 8 3.175 mm screws that secure the motherboard in place.
    • Remove by turning counter clockwise using a Phillips #0 bit with the correct screwdriver using medium/ firm pressure, assuring that you don't strip the screws.
    • Set aside
    Chiedi a FixBot
    Aggiungi Commento
  6. BLU Studio G Screen Replacement: passo 6, immagine 1 di 3 BLU Studio G Screen Replacement: passo 6, immagine 2 di 3 BLU Studio G Screen Replacement: passo 6, immagine 3 di 3
    • Locate the two connector clamps on the motherboard.
    • Carefully place the tip of a precision tweezer or metal spudger under the short light brown plastic clamp. This will release the connectors.
    • Gently pull out the connectors from the clamp inserts by pulling slowly away from of device using precision tweezers.
    Chiedi a FixBot
    Aggiungi Commento
  7. BLU Studio G Screen Replacement: passo 7, immagine 1 di 1
    • Locate the speaker on the bottom of the device and slowly pry upwards and to the right as its wired to the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  8. BLU Studio G Screen Replacement: passo 8, immagine 1 di 3 BLU Studio G Screen Replacement: passo 8, immagine 2 di 3 BLU Studio G Screen Replacement: passo 8, immagine 3 di 3
    • Locate the volume button strip on the left side of the device and slowly pry outwards from one end to the other from the device.
    • Carefully pull over the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  9. BLU Studio G Screen Replacement, Screen: passo 9, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    • Turn the phone over after detaching the connectors that were attached to the motherboard
    • Carefully pry between the screen and the bevel with precision tweezers lifting slowly separating the screen.
    • Use of another thin tool will help support the lifting
    Chiedi a FixBot
    Aggiungi Commento
  10. BLU Studio G Screen Replacement: passo 10, immagine 1 di 3 BLU Studio G Screen Replacement: passo 10, immagine 2 di 3 BLU Studio G Screen Replacement: passo 10, immagine 3 di 3
    • Insert the metal spudger between the screen and the frame, using the blue plastic tool as a brace to prevent the screen from reattaching to the frame.
    • To fully remove the screen from the frame, repeat the previous step around the entire perimeter of the device.
    • Carefully remove the screen.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
5Commenti sulla guida
Thank YOU and I will begin disassembling my BLU as soon as I receive a phone screen. that is entirely different but resembles my BLU enough to use these steps to complete the mission.
Lamiah - Rispondi Condividi
Can anyone tell me where I can buy a screen for a blu view 3
Thank you
mrcblake50@gmail.com
Charles Blake (Mr Blake) - Rispondi Condividi
Most thorough and informative procedure out of the many I reviewed. Thank you.
Alan Doud - Rispondi Condividi
I need screen fue the sam3 ministerio blu.where to buy
Alexis urdaneta - Rispondi Condividi
Hi
I need digitizer where can I get one
Pls reply
Thanks
BiD N Buy - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 4
Ultimi 30 giorni: 30
Tutti i Tempi: 2,493
