Salta al contenuto principale
BLU Life X8 Front Camera Replacement
Cosa ti serve
  1. BLU Life X8 Front Camera Replacement, Battery: passo 1, immagine 1 di 2 BLU Life X8 Front Camera Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the phone over so that the screen is facing down.
    • Slide the opening tool between the micro-USB port and the back cover.
    • Use the opening tool to create a gap.
    Chiedi a FixBot
    Aggiungi Commento
  2. BLU Life X8 Front Camera Replacement: passo 2, immagine 1 di 1
    • Use your thumb to pry off the back panel once the gap is large enough.
    Chiedi a FixBot
    Aggiungi Commento
  3. BLU Life X8 Front Camera Replacement: passo 3, immagine 1 di 1
    • Once the back panel is off, locate the indent at the bottom of the battery.
    • Use your thumb to slip the battery out of the case.
    Chiedi a FixBot
    Aggiungi Commento
  4. BLU Life X8 Front Camera Replacement, Motherboard: passo 4, immagine 1 di 2 BLU Life X8 Front Camera Replacement, Motherboard: passo 4, immagine 2 di 2
    • Use the Phillips #00 bit to undo the nine 1.5mm screws from the back of the device.
    Chiedi a FixBot
    Aggiungi Commento
  5. BLU Life X8 Front Camera Replacement: passo 5, immagine 1 di 1
    • Wedge the opening tool into the seam of between the screen and the gray frame.
    • Run the opening tool along the seam to release the clips that hold the two pieces together.
    • You may need to use the opening picks to prevent the clips from re-engaging.
    Chiedi a FixBot
    Aggiungi Commento
  6. BLU Life X8 Front Camera Replacement: passo 6, immagine 1 di 1
    • Once all the clips have been released, lift the frame and set it aside.
    Chiedi a FixBot
    Aggiungi Commento
  7. BLU Life X8 Front Camera Replacement: passo 7, immagine 1 di 2 BLU Life X8 Front Camera Replacement: passo 7, immagine 2 di 2
    • Use the Phillips #00 Phillips bit to undo the two 1.5mm screws from the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  8. BLU Life X8 Front Camera Replacement: passo 8, immagine 1 di 3 BLU Life X8 Front Camera Replacement: passo 8, immagine 2 di 3 BLU Life X8 Front Camera Replacement: passo 8, immagine 3 di 3
    Strumento utilizzato in questo passaggio:
    • Use the tweezers to peel away the mesh tape and reveal the ribbon connectors.
    • Use the tweezers to lift the brown and black tabs to release the ribbon cables and unlock them.
    Chiedi a FixBot
    Aggiungi Commento
  9. BLU Life X8 Front Camera Replacement: passo 9, immagine 1 di 1
    • The ribbon cables should be free. Pull back on the ribbons to release them from their connectors.
    Chiedi a FixBot
    Aggiungi Commento
  10. BLU Life X8 Front Camera Replacement: passo 10, immagine 1 di 1
    • Slowly lift the vibration motor away from the frame and peel up the tape.
    Chiedi a FixBot
    Aggiungi Commento
  11. BLU Life X8 Front Camera Replacement, Front Camera: passo 11, immagine 1 di 1
    • Flip the motherboard over.
    • Lift the front camera from its housing.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
USF Tampa, Team S1-G2, Nance Fall 2017 Membro di USF Tampa, Team S1-G2, Nance Fall 2017
USFT-NANCE-F17S1G2
4 Membri
12 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 20
Tutti i Tempi: 449
