Salta al contenuto principale
B. Front Panel
Cosa ti serve
    1. B. Front Panel, Front Panel Assembly: passo 1, immagine 1 di 2 B. Front Panel, Front Panel Assembly: passo 1, immagine 2 di 2
      • Start by placing the NeoPixel rings into the circles. Make sure the pins are at the top center.
      • Thread the Inner Fan part into the circle.
      • Thread the tip into the Inner Fan.
      Chiedi a FixBot
      Aggiungi Commento
    2. B. Front Panel, Front Panel Assembly: passo 2, immagine 1 di 2 B. Front Panel, Front Panel Assembly: passo 2, immagine 2 di 2
      • Screw the assembled Circle parts into the Front Face using 12x M3x8 countersunk screws
      Chiedi a FixBot
      Aggiungi Commento
    3. B. Front Panel, Front Panel Assembly: passo 3, immagine 1 di 3 B. Front Panel, Front Panel Assembly: passo 3, immagine 2 di 3 B. Front Panel, Front Panel Assembly: passo 3, immagine 3 di 3
      • Glue the letters into the Middle Name Plate
      • Slide in the Middle Name Plate, Left and Right Nets into the Assembled Front Panel
      • Using 2x M3x8 button head screws secure the Middle Name Plate to the Assembled Front Panel.
      Chiedi a FixBot
      Aggiungi Commento
    4. B. Front Panel, Front Panel Assembly: passo 4, immagine 1 di 1
      • Slide in the Left and Right Grill into the Front Panel Assembly
      Chiedi a FixBot
      Aggiungi Commento
    5. B. Front Panel, Front Panel Mounting: passo 5, immagine 1 di 2 B. Front Panel, Front Panel Mounting: passo 5, immagine 2 di 2
      • The Front Panel mounts to the Frame with 4x M3x8 socket head/button head screws with 4x M3 T-Nuts and 2x M5x10 button head screws with 2 M5 T-Nuts
      • The Left and Right Lower Front Grill mount to the frame of the printer with 4x M3x8 button head screws with 4x M3 T-Nuts
      Chiedi a FixBot
      Aggiungi Commento
    6. B. Front Panel, LCD: passo 6, immagine 1 di 3 B. Front Panel, LCD: passo 6, immagine 2 di 3 B. Front Panel, LCD: passo 6, immagine 3 di 3
      • Mount the backplate to the arm with 2x M3x8 button head screws.
      • Mount the ball to the arm with 1x M3x8 socket head screw.
      • I also used a drop of superglue.
      • Insert the PanelDue into the backplate lining up the screw holes. Screw the backplate to the front plate with 4x M3x10 button head screws.
      • Mount the full assembly to the front frame re-enforcement with 2x M5x10 button head screws and 2x M5 T-nuts
      Chiedi a FixBot
      Aggiungi Commento
    7. B. Front Panel, Results: passo 7, immagine 1 di 2 B. Front Panel, Results: passo 7, immagine 2 di 2
      • Looks pretty cool huh?
      Chiedi a FixBot
      Aggiungi Commento
Linea Traguardo
Altre 4 persone hanno completato questa guida.
David Husolo
Membro da: 06/16/21
9.382 Reputazione
33 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 28
Tutti i Tempi: 1,693
