Salta al contenuto principale
Axess SPBT1031 Subwoofer Replacement
Cosa ti serve
  1. Axess SPBT1031 Subwoofer Replacement, Subwoofer: passo 1, immagine 1 di 1
    • Look at the side of the speaker without the red interface plate; there will be a red ring around the mesh but no buttons on the side.
    • Remove the two 5.5 mm screws from the top and bottom of the black face plate using a Phillips #1 screwdriver.
    • Do not remove the plate yet.
    Chiedi a FixBot
    Aggiungi Commento
  2. Axess SPBT1031 Subwoofer Replacement: passo 2, immagine 1 di 1
    • Use a metal spudger to remove the mesh speaker cover by wedging the narrow end into the center of the outer edge of the mesh touching the red plate.
    Chiedi a FixBot
    Aggiungi Commento
  3. Axess SPBT1031 Subwoofer Replacement: passo 3, immagine 1 di 2 Axess SPBT1031 Subwoofer Replacement: passo 3, immagine 2 di 2
    • Remove four 5.5 mm screws from the red panel under the mesh using a Phillips #1 screwdriver.
    • For subwoofer replacement there will be four screws to remove and four bolts as well. The bolts are used for alignment and cannot be removed.
    Chiedi a FixBot
    Aggiungi Commento
  4. Axess SPBT1031 Subwoofer Replacement: passo 4, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    • If the screws are difficult to remove, use the tweezers to twist and pick them out.
    Chiedi a FixBot
    Aggiungi Commento
  5. Axess SPBT1031 Subwoofer Replacement: passo 5, immagine 1 di 1
    • Separate the red plate from the black face plate by removing the black plate from the tube and pushing on the inside of the subwoofer.
    • Be careful not to damage the black face plate or red plate as you pull them apart.
    • You may place the black faceplate back on the tube, but do not screw it back in yet.
    Chiedi a FixBot
    Aggiungi Commento
  6. Axess SPBT1031 Subwoofer Replacement: passo 6, immagine 1 di 2 Axess SPBT1031 Subwoofer Replacement: passo 6, immagine 2 di 2
    • To remove the the wires from the subwoofer terminals, use a soldering iron to reheat the solder at each of the four points of connection.
    Chiedi a FixBot
    Aggiungi Commento
  7. Axess SPBT1031 Subwoofer Replacement: passo 7, immagine 1 di 1
    Desoldering Pump
    $3.99
    Chiedi a FixBot
    Aggiungi Commento
  8. Axess SPBT1031 Subwoofer Replacement: passo 8, immagine 1 di 1
    • Remove the old subwoofer.
    • Connect the brown wires to the positive terminals and the black ones to the negative terminals when re-soldering.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
1Commento della guida
I Ned to replace the charger conection and I need the parts please u can email me at elpaleterolopez@Gmail.com or call me at 6613402547
Ramon lopez - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 6
Ultimi 30 giorni: 27
Tutti i Tempi: 2,032
