Salta al contenuto principale
Automatic Tommy 20 Trigger Spring Replacement
Cosa ti serve
  1. Automatic Tommy 20 Trigger Spring Replacement, Splitting the Gun into Two Halves: passo 1, immagine 1 di 2 Automatic Tommy 20 Trigger Spring Replacement, Splitting the Gun into Two Halves: passo 1, immagine 2 di 2
    • Locate the orange slider on the front side of the gun.
    • Pull the orange slider towards the back of the gun while lifting up on the nose the gun.
    Chiedi a FixBot
    Aggiungi Commento
  2. Automatic Tommy 20 Trigger Spring Replacement: passo 2, immagine 1 di 3 Automatic Tommy 20 Trigger Spring Replacement: passo 2, immagine 2 di 3 Automatic Tommy 20 Trigger Spring Replacement: passo 2, immagine 3 di 3
    • Remove the single 1/8 in. screw at the junction of the body and the nose using a Philips #00 Screwdriver.
    • Remove all parts within the chamber to be able to completely detach the nose of the gun.
    • Be careful to keep track of all the components for reassembly.
    Chiedi a FixBot
    Aggiungi Commento
  3. Automatic Tommy 20 Trigger Spring Replacement, Ammo Drum: passo 3, immagine 1 di 3 Automatic Tommy 20 Trigger Spring Replacement, Ammo Drum: passo 3, immagine 2 di 3 Automatic Tommy 20 Trigger Spring Replacement, Ammo Drum: passo 3, immagine 3 di 3
    • Remove the 1/16 in. screws using a Phillips #00 Screwdriver as indicated in the photo on the left.
    • Remove the 1 mm screw on the battery lid using a Philips #1 Screwdriver as indicated in the photo on the left.
    Chiedi a FixBot
    Aggiungi Commento
  4. Automatic Tommy 20 Trigger Spring Replacement: passo 4, immagine 1 di 1
    • Carefully spread apart the two halves of the gun, and lift out the ammo drum.
    Chiedi a FixBot
    Aggiungi Commento
  5. Automatic Tommy 20 Trigger Spring Replacement, Split the Gun into Two Halves: passo 5, immagine 1 di 2 Automatic Tommy 20 Trigger Spring Replacement, Split the Gun into Two Halves: passo 5, immagine 2 di 2
    • Grab both sides of the gun and pull forcefully in an upward and outward motion to remove from the light green stock.
    • If this is your first time disassembling your gun, the stock will be glued to each half of the gun's body. To break off the stock from the frame of the gun, you will need to careful wiggle the two halves so that the glue will break apart. The plastic on the gun may break or warp slightly.
    Chiedi a FixBot
    Aggiungi Commento
  6. Automatic Tommy 20 Trigger Spring Replacement, Removing the Battery Box: passo 6, immagine 1 di 2 Automatic Tommy 20 Trigger Spring Replacement, Removing the Battery Box: passo 6, immagine 2 di 2
    • Remove the two 1/16 in. screws attaching the battery box to the frame of the gun using a Phillips #00 Screwdriver.
    • Lift the battery box off the frame of the gun to give yourself access to the trigger mechanism.
    Chiedi a FixBot
    Aggiungi Commento
  7. Automatic Tommy 20 Trigger Spring Replacement, Removing the Screws from the Trigger Mechanism: passo 7, immagine 1 di 1
    • Remove the two 1/6 in. screws connecting the trigger and trigger spring to the frame of the gun using a Phillips #00 Screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  8. Automatic Tommy 20 Trigger Spring Replacement: passo 8, immagine 1 di 2 Automatic Tommy 20 Trigger Spring Replacement: passo 8, immagine 2 di 2
    • Lift the plastic trigger away from the gun along with the attached spring.
    • Make sure you do not lift the trigger without the spring or the spring may stretch and no longer function properly.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 6-22, Maness Fall 2014 Membro di Cal Poly, Team 6-22, Maness Fall 2014
CPSU-MANESS-F14S6G22
4 Membri
6 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 43
Tutti i Tempi: 1,243
