Salta al contenuto principale
August Smart Lock Gear Replacement
Cosa ti serve
    1. August Smart Lock Gear Replacement, Gear: passo 1, immagine 1 di 3 August Smart Lock Gear Replacement, Gear: passo 1, immagine 2 di 3 August Smart Lock Gear Replacement, Gear: passo 1, immagine 3 di 3
      • Flip the device over so the metal plate is facing you.
      • Undo the latches on the side to remove the metal plate.
      • Using a Phillips #0 screwdriver, remove the black screws to release the back cover.
      • To unscrew all of the screws, you will need to close the latches again.
      • Do not pull the cover apart too far as the speaker is in the cover and connected to the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    2. August Smart Lock Gear Replacement: passo 2, immagine 1 di 3 August Smart Lock Gear Replacement: passo 2, immagine 2 di 3 August Smart Lock Gear Replacement: passo 2, immagine 3 di 3
      • Lift the cover off the device and set to the side.
      • The cover contains the speaker which is connected to the motherboard so do not pull to far apart.
      • Remove the gears as shown.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 12 persone hanno completato questa guida.
USF Tampa, Team S11-G6, Passmore Fall 2017 Membro di USF Tampa, Team S11-G6, Passmore Fall 2017
USFT-PASSMORE-F17S11G6
4 Membri
6 guide realizzate
8Commenti sulla guida
The tittle of this topic is: August Smart Lock Gear Replacement, but I don't see any spare part replacement at all!
Walter Quintero - Rispondi Condividi
Any tips on where to get replacement gears?
Byron H - Rispondi Condividi
The gear connecting the motor is cracked. I'd also like to know where to get parts other than buying another broken August lock that's broken in another way.
Robert F. Jobin Jr. - Rispondi Condividi
Robert, where you able to find this replacement gear? Mine broke this week and having a hard time to find the part. Thanks
Luiz Cavalcante - Rispondi Condividi
Anyone find gear replacements? The. Am on the motor shaft cracked on mine
pennytrotz - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 7
Ultimi 7 giorni: 12
Ultimi 30 giorni: 64
Tutti i Tempi: 14,064
