Salta al contenuto principale
August Smart Lock Accelerometer Replacement
Cosa ti serve
    1. August Smart Lock Accelerometer Replacement, Accelerometer: passo 1, immagine 1 di 3 August Smart Lock Accelerometer Replacement, Accelerometer: passo 1, immagine 2 di 3 August Smart Lock Accelerometer Replacement, Accelerometer: passo 1, immagine 3 di 3
      • Flip device over so the black bottom is facing you.
      • Undo latches on both sides to remove the metal cover.
      • Using a Phillips #0 screwdriver, remove the black screws to release the back cover.
      • To unscrew all of the screws, you will need to close the latches again.
      • When you lift off the cover, be careful not to lift to far up. The cover contains the speaker which is connected to the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    2. August Smart Lock Accelerometer Replacement: passo 2, immagine 1 di 3 August Smart Lock Accelerometer Replacement: passo 2, immagine 2 di 3 August Smart Lock Accelerometer Replacement: passo 2, immagine 3 di 3
      • Grab the gears and lift them up to remove from the device
      Chiedi a FixBot
      Aggiungi Commento
    3. August Smart Lock Accelerometer Replacement: passo 3, immagine 1 di 3 August Smart Lock Accelerometer Replacement: passo 3, immagine 2 di 3 August Smart Lock Accelerometer Replacement: passo 3, immagine 3 di 3
      • Remove the (3) three silver screws by the motor using a Phillips #0 screwdriver.
      • Disconnect the speaker plug from the motherboard
      • Disconnect the battery plugs from the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    4. August Smart Lock Accelerometer Replacement: passo 4, immagine 1 di 1
      • Once the speaker is disconnected, remove the back cover.
      • Lift up the motherboard and motor assembly out of the device.
      Chiedi a FixBot
      Aggiungi Commento
    5. August Smart Lock Accelerometer Replacement: passo 5, immagine 1 di 2 August Smart Lock Accelerometer Replacement: passo 5, immagine 2 di 2
      • Locate the Accelerometer. It is attached to the motherboard by a ribbon.
      • Lift up the black tab to remove the ribbon from the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 8 persone hanno completato questa guida.
USF Tampa, Team S11-G6, Passmore Fall 2017 Membro di USF Tampa, Team S11-G6, Passmore Fall 2017
USFT-PASSMORE-F17S11G6
4 Membri
6 guide realizzate
7Commenti sulla guida
Any idea where can I get a new accelerometer to complete this repair?
Thai Nguyen - Rispondi Condividi
Where can we get a new accelerometer. My phone was not connecting because of the ribbon was broken inside
Dinesh Sharma - Rispondi Condividi
Same as above…. where to locate an accelerometer??
osallabe - Rispondi Condividi
Did anyone find out where to buy the part?
LBurd - Rispondi Condividi
Where can I find one
Jeff Wasilewski - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 13
Ultimi 30 giorni: 60
Tutti i Tempi: 8,882
