Salta al contenuto principale
Atari Flashback 2 Reset and Select Button Replacement
Cosa ti serve
  1. Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: passo 1, immagine 1 di 3 Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: passo 1, immagine 2 di 3 Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: passo 1, immagine 3 di 3
    • Using the screwdriver and the PH1 bit, unscrew the five 10.0 mm screws on the bottom of the console.
    • One screw is under the main sticker in the middle of the console.
    Chiedi a FixBot
    Aggiungi Commento
  2. Atari Flashback 2 Reset and Select Button Replacement: passo 2, immagine 1 di 3 Atari Flashback 2 Reset and Select Button Replacement: passo 2, immagine 2 di 3 Atari Flashback 2 Reset and Select Button Replacement: passo 2, immagine 3 di 3
    • Unscrew the six 9.0 mm Phillips #1 screws on the brown circuit board that correspond to the reset and select buttons.
    • Remove gently. The circuit board is connected by wire to the console. Removing the cable from the console case may allow more slack.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
2Commenti sulla guida
Good night! I have a flashback2 atari which burst the capacitor EC1, could you help me with its value? Thank you!
pradose - Rispondi Condividi
Hi pradose! We no longer have the device so it will not be possible for our team to walk you through anything beyond the guides we posted.
Daniel Hoffman - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 11
Ultimi 30 giorni: 50
Tutti i Tempi: 1,414
